Help plz with tire pressure sensor!!
Old 05-08-12, 07:51 PM
CrzKush
CrzKush's Avatar
Default Help plz with tire pressure sensor!!
Hi! I recently slapped on my tires on an after market rim but the problem is that the valve stem hole on the after market rim is tiny and it won't fit my OEM Valve stem with a sensor on it. Does any one have this problem? Is there any option I can fix this?
Old 05-08-12, 07:58 PM
lexuswtf
lexuswtf's Avatar
take ur TPMS sensors and throw 'em in the trunk ;-)
Old 05-08-12, 07:59 PM
RCB
RCB's Avatar
Some aftermarket rims are not designed for TPMS sensors. Make a pipe bomb if you want the light to go out.
Old 05-08-12, 09:39 PM
boostftw
boostftw's Avatar
heres the DIY for it:
https://www.clublexus.com/forums/is-...pipe-bomb.html
Old 05-09-12, 11:39 AM
digger08
digger08's Avatar
Do you really have a different size valve stem hole?..... I thought there was a standard fitment size (.453 diameter) that is universally accepted? The angle of the sensor on the rim edge or depth of the rim is usually the reason.
A reputable tire shop may also be able to bore out the hole larger or you can also try a universal strap and TPMS clip system that will hold the sensors to each barrel.
FYI - I made a TPMS pressure vessel so i could run my rays valve stems/ I did not trust the strap barrel system - It is not as easy as the DIY suggests and took me at least 4 prototypes to get it correct. It takes some time to correctly set the pressure and initialize the vehicle as well to prevent expansion and contraction that happens during seasonal changes in Canada.
Just do not expect to knock out this project on the first try - it will take few weeks to get it right and you will need access to a cooperative dealer or Toyota Techstream to register your new or second set of sensors (as you will be sealing a set in the simulator) You will not want to be opening this thing up every spring once you get it right. You can also try a set of EZ sensors that clone your original transmitting ID's - these may or may not fit better and can be a lot cheaper than buying a second set of sensors.
Digger08
Old 05-09-12, 11:43 AM
staman
staman's Avatar
CrzKush. Where are you located. I have a set of aftermarket TPMS sensors that came off my wedsport rims. They are slightly smaller than the OEM i believe...You can try them out if you like...
Old 05-09-12, 03:57 PM
ming15237
ming15237's Avatar
Default tpms
There is a system out there that you can instal "clone" sensors in your aftermarket wheels. if you pm me a pic of your wheels I will tell you which ones will fit.
Old 05-09-12, 04:19 PM
Evil Teo
Evil Teo's Avatar
how does the clone work? has anyone use it?
Old 05-10-12, 08:35 AM
digger08
digger08's Avatar
Simply....
There is lots of types of these sensors in the marketplace- They work similar to programming a universal remote control.
The most popular and quality ones are "EZ Sensors" made by Schrader - they clone the existing signal and are programmable with a TPMS relearn tool.
Other universal Sensors - have the code already embedded and need to be activated
The benefit to you, is that aftermarket service providers and tire shops need only the basic tools to set up your vehicle. As of now, if you wanted to connect a set of OEM Pacific sensors, you must have Toyota software, as no aftermarket TPMS equipment can support out current sensor types.
Digger08
Old 05-10-12, 09:40 AM
Evil Teo
Evil Teo's Avatar
Has anyone use the clones on our cars?
Monique023
10-01-14 06:46 PM
byung
Wheels, Tires & Brakes Forum
04-24-10 09:56 AM
gcam77
09-12-08 01:46 PM
kilo6_one
12-03-06 05:37 PM
viet658
12-14-05 10:31 PM
Quick Reply: Help plz with tire pressure sensor!!
