Looking for New Brakes and Rotor for IS-F
Old 11-26-10, 03:08 PM
langood
langood's Avatar
Default Looking for New Brakes and Rotor for IS-F
Hi All,
it is time to change Front and Rear Brakes, anyone can suggest me any brand for Front and Rear brakes and rotors?
Old 11-26-10, 03:24 PM
yemgi
yemgi's Avatar
for rotors I would suggest OEM (Brembo) or Brembo
What do you mean by brakes? Is it pads you are after ? If so HPS are quite good
Old 11-26-10, 04:39 PM
SCCAForums
SCCAForums's Avatar
www.ctbrakes.com
Carbotech is what most I know are running, with great results. (For Brake Pads)
A couple have used different brand rotors... not sure which, I'm sure they'll chime in soon though.
Dave
Old 11-26-10, 06:24 PM
zojirushi
zojirushi's Avatar
I thought about getting the HPS from Hawk but changed my mind because they don't have an application for the rear brakes.
Old 11-26-10, 06:57 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
Originally Posted by langood
Hi All,
There's been so many threads about brakes in this forum that another thread is
Search is your friend. You should start here:
https://www.clublexus.com/forums/is-...struction.html
Lou
Old 11-27-10, 10:10 AM
langood
langood's Avatar
So, Rotor suggest use back OEM, and Pads can use aftermarket? which brand you suggest?
Old 11-27-10, 10:11 AM
langood
langood's Avatar
Originally Posted by SCCAForums
www.ctbrakes.com
Dave
Hi Dave, how about Rotors?
Old 11-27-10, 04:06 PM
SCCAForums
SCCAForums's Avatar
I want to say someone purchased a set of rotors from 'www.rockauto.com' not sure of the brand.
It may be in that other link that was posted... can't remember... but from what I remember they seemed to say the aftermarket rotors were fine.
Only thing is they are 'no longer' left and right for the hole vents... they are the same direction.
Peace,
Dave
Old 11-27-10, 04:55 PM
verals05
verals05's Avatar
I use the Raybesto ones. No problem at all with fading. I haven't used them on the track yet. But they worked great on a mountain run I did.
Old 11-28-10, 06:24 AM
Raffy
Raffy's Avatar
I have Prodrive brake pads (winmax) which I got from a local Prodrive Japan dealer. Prodrive has 3 compounds available for both front and rear calipers if the IS F.
Old 11-28-10, 04:46 PM
PHXF
PHXF's Avatar
I suggest checking your rotor spec and NOT replacing them if they are still in spec (I assume you haven't already changed your pads once, so you should only be around 20k miles...likely you have 1-1.2mm of spec wear left.
I did a simple pad swap and bedding procedure and they are quiet, low dust, and fee great. Couldn't be happier.
Old 11-28-10, 06:57 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
+1. VERY unlikely the discs are worn out.
The price on the OEM rotors has jumped considerably in the last couple of months. I bought mine for $197 each before the price increase. The same vendor now lists them at $321 each. I'm getting mine cryo treated right now.
Rock Auto sells Raybestos discs. They are functional equivalents, but I do not know if they tolerate road course abuse as well as the Brembo discs do. Either will be fine for street and drag racing.
Old 12-03-10, 10:47 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Peace,
Dave
Bad news Dave...!!
The OEM's are exactly the same way..
One part number for the Fronts and One part number for the Rears
Joe Z
Old 12-04-10, 09:13 AM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
I'm selling my Brembo Gran Turismo big brake kit for the Lexus IS-F... Full two piece floating rotors front and rear...front rotors are 15.2 in and rear is 13.6.
Old 12-04-10, 09:20 AM
Joe Z
Joe Z's Avatar
^^ So what color LFA did you order??? Since your now selling the F for a "Gentleman's Car"..
~ Joe Z
Quick Reply: Looking for New Brakes and Rotor for IS-F
