Personalize Setting: Seat Belt Buzz Off
Old 01-02-11, 03:08 PM
  #31
J2K
J2K's Avatar
Thanks Joe! I've been listening to that seat belt ding way too long.
Old 01-02-11, 07:38 PM
  #32
Gymkata
Gymkata's Avatar
Awesome Thanks. I didn't know that was possible.
Old 01-09-11, 06:27 PM
  #33
bb_ae86
bb_ae86's Avatar
Thanks for the info! Confirming that it works on 2011 ISF's too.
Old 01-15-11, 07:26 PM
  #34
GaRedSupra
GaRedSupra's Avatar
This is one of the simplest best mods ever. That seat belt noise was so freaking annoying.
Old 03-18-13, 01:52 PM
  #35
Rossi
Rossi's Avatar
It worked great.
-thank you so much!
Old 03-18-13, 02:42 PM
  #36
bnizzle87
bnizzle87's Avatar
It's the best couple of minutes you'll ever spend. Simple mod, but gotta make sure you hold the button down for an adequate amount of time.
Old 03-18-13, 04:54 PM
  #37
jack7824
jack7824's Avatar
Thanks. That chime is agitating.
Old 03-18-13, 08:12 PM
  #38
g356gear
g356gear's Avatar
Done! Thanks....worked perfectly!
Old 03-18-13, 10:11 PM
  #39
LO 21
LO 21's Avatar
On this topic, what's with the chime that doesn't stop when we turn the car off? Like the sound the cars used to make when the key is in the ignition with the door open. Any way to get rid of it?? If we've already turned the car off, why on earth would it chime like that?
Old 03-18-13, 10:42 PM
  #40
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
No way to get rid of it. I hate it too and I've tried to find a simple fix. There is none documented anywhere.
Old 03-19-13, 06:23 PM
  #41
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb
Push the rubber door switch with your left hand....
Or
Turn the car OFF before opening drivers door.. Problem solved !!!
Joe Z
Old 03-19-13, 11:37 PM
  #42
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Yeah, that's a work around not a fix....
Old 12-09-23, 01:49 PM
  #43
jeffnote
1st Gear
jeffnote's Avatar
Originally Posted by Joe Z
^^ No Problem..
^^ Yes
Joe. I have a 2006 Lexus ES 330 and it does not have the push button ignition. Is there a method for me to disable the door chime on my year model Lexus? I have a 2006 Lexus ES 330 and it does not have the push button ignition. Is there a method for me to disable the door chime on my year model Lexus? Thanks in advance
Old 07-01-24, 07:52 PM
  #44
Rossi
Rossi's Avatar
THE DEALERSHIP LIED TO YOU...
This is not an LPS setting.. Think of it has a cheat code.. LoL
With car ON.. make sure the Trip-O-meter is set to ODO..
Turn off car...
Push the start button twice.. (Do Not press pedal)
As soon as the gauges begin cycling.
Press and hold the trip button for 10 mississippi’s... count them out, its fun!
On the 10th one, click and fasten your drivers seat belt.. still holding the trip button down..
A selection will appear in the ODO section that says "B-ON" or "B-OFF".
Press the trip button till it reads B-OFF....
Power off the car & You are done..
Joe Z
Old 07-01-24, 08:32 PM
  #45
Bechtold
Bechtold's Avatar
My wife has a 2013 IS 350 so I will try this. Is there any version of this for the 3IS by chance?
Quick Reply: Personalize Setting: Seat Belt Buzz Off
