Does anyone make a NOS tune?
Old 05-21-20, 06:54 AM
AlOtaBblGm
AlOtaBblGm's Avatar
Default Does anyone make a NOS tune?
Seems like a cool thing to do and with all the capability we have with tunes these days. Just an on-off type thing. Squeezing or not. Adjusts ignition timing, checks for fuel pressure, throttle position, rpm, 2nd gear trigger, etc.
Old 05-21-20, 07:08 AM
Joker4096
Joker4096's Avatar
This would be cool. I don't think our ECU tuning programs have the ability to use an input. I may be wrong but thisuthis is only available with stand alone systems or a true tuning program. Waiting for RR Racing response with this.
Old 05-21-20, 07:22 AM
AlOtaBblGm
AlOtaBblGm's Avatar
The tune could hijack a trivial input and use that as an enable input. There must be something that is usually not needed, like the SNOW mode select.
Old 05-21-20, 07:23 AM
Joker4096
Joker4096's Avatar
It would depend on if the program has the ability to use inputs.
Old 05-22-20, 07:19 AM
Patton6964
Patton6964's Avatar
Joker, didn't you have a N20 setup?
I actually really want to do one myself. I wouldn't do more than 100 shot and would do as many safety measures as possible to protect the engine & tranny.
I've been tossing around the idea of buying the SC kit from RR but honestly, it just doesn't make sense for me $$$ wise. I wouldn't use the SC to it's full ability on a regular basis and like the idea of just being able to flip a switch and get extra HP and only be putting stress on the engine & tranny once in a while vs all the time.
Old 05-22-20, 07:26 AM
Joker4096
Joker4096's Avatar
Yes I have a wet nitrous setup on my car right now actually. How many times I have used it, maybe just one 10 lbs bottle in about 3 years or so. I guess I don't do enough racing.
Old 05-22-20, 06:06 PM
AlOtaBblGm
AlOtaBblGm's Avatar
I like the NOS option because it is cheap and can give a boost when I want it. There's so much capability in these ECMs to monitor the engine unlike the old days when you had to be careful.
Old 05-24-20, 02:18 PM
Patton6964
Patton6964's Avatar
How big of a shot are you running? What all do you have hooked up? Purge, auto warmer, gauges etc.?
Old 05-25-20, 02:52 PM
Joker4096
Joker4096's Avatar
I think I have a 120 shot or something. I have a heater, purge solenoid and a NOS wide open switch controller. I monitor what the afr are using the stock sensors and Torque Pro or the OBD Fusion app with a Bluetooth adapter.
suprasoup
Performance & Maintenance
02-08-19 08:15 AM
petedrex
10-13-13 10:20 AM
1jzchris
18
12-17-12 05:08 PM
RocketGuy3
09-07-10 08:15 PM
Quick Reply: Does anyone make a NOS tune?
