IS C Discussion about the convertible IS C model
Can my 2010 IS 250c listen to music through bluetooth?
Old 06-03-14, 12:03 PM
shibiscuit
shibiscuit's Avatar
Default Can my 2010 IS 250c listen to music through bluetooth?
I've been using the AUX cable but it'd be so much nicer if I could change the songs with the buttons on my wheel instead of having to look down at my phone and changing it there. I tried connecting it to the USB port but it still didn't work.. is there a way to do this?
Old 06-03-14, 05:49 PM
Drone619
Drone619's Avatar
Yes you can, just set your Bluetooth to connect to your phone which will enable the Bluetooth audio to work also. It works with my pandora, soundcloud, and iPhone
Old 06-09-14, 01:58 PM
shibiscuit
shibiscuit's Avatar
I'm using a Samsung Note 3 and I've tried this before, unfortunately, it doesn't work. Is this just an Android vs. iPhone difference?
Old 06-26-14, 08:31 PM
fknISC808
fknISC808's Avatar
Do you have NAV? I have nav and connect my S5 via bluetooth, I use spotify and can control everything from steering wheel. Track info displays as well. I dont know if it is the same for non-nav models.
Old 08-27-14, 02:10 AM
shibiscuit
shibiscuit's Avatar
Sorry for the old bump, but I still haven't solved this problem yet. I took it to the dealer and they said "they didn't know"
And yes, I do have NAV.
Edit: Figured it out! Yes!
Old 08-27-14, 05:35 AM
13IS250C
13IS250C's Avatar
The little tabs across the top like FM and SAT and CD, is there one that says BT Audio?
If that tab is pressed on mine, all I have to do is get in my car with my iPhone and it starts playing. I just love it!!!!
Old 08-30-14, 06:27 PM
rxonmymind
rxonmymind's Avatar
Wooohooo! I did it. I have a Droid RAZR model CE0168. I was able to set it up via the SETUP on the ML and got my wife's Samsung Galaxy to sing also. Very happy.
Attached Thumbnails Can my 2010 IS 250c listen to music through bluetooth?-img_20140830_182054_868.jpg
Old 10-16-15, 02:26 AM
Jdv38
Jdv38's Avatar
How did you do it?
justin1203
RX - 3rd Gen (2010-2015)
04-24-18 10:20 AM
kjmff5
10-12-13 11:22 AM
tukai
04-11-12 01:47 PM
wkw84
03-24-10 02:08 PM
freqfly
04-22-08 09:01 AM
Quick Reply: Can my 2010 IS 250c listen to music through bluetooth?
