IS C Discussion about the convertible IS C model
Rear deck rattle with top up - TSB?
Old 10-27-14, 09:12 PM
travelride
travelride's Avatar
Default Rear deck rattle with top up - TSB?
Anyone else struggling with a rattle that seems to be coming from the rear deck when the top is up? I already had it to the dealer once and they said they fixed it. Drove it out of there and the rattle was back immediately. I swear they must not have test driven the car after they thought they had the rattle fixed or they would have known they failed to fix it.
Any suggestions?
Old 10-28-14, 05:39 AM
jgr7
jgr7's Avatar
Take it back and go for a ride with the tech, make sure you drive on the little dots on the center lines and it should make the noise.
Old 10-31-14, 12:42 PM
Machog
Machog's Avatar
If you are sure its rear deck lid, I can't offer any suggestions. There is a known rattle above the passengers head, more towards the window. Had mine in under warranty and it was fixed with a simple adjustment. Hasn't come back in nearly a year. Try taking every thing out of the car that isn't bolted down-including the spare, tool kit, nothing in the glove box, arm rest, under seats etc. Cars have very strange acoustics and it can take forever to pin point the problem.
Machog
Old 11-05-14, 07:11 PM
Jamessasso
Jamessasso's Avatar
It's not the rear deck. It sounds like it. There is actually a bulletin on how to fix it. A quick fix would be to add tension to the j hooks on each side of the 2nd panel. They are hidden behind the plastic trim. That's more then likely then problem.
Old 11-12-14, 11:52 AM
13IS250C
13IS250C's Avatar
I had the rattle on the drivers side between the windows. They fixed that, now my rear deck rattles. I give up. I'm going to go buy a more powerful stereo.
Old 11-12-14, 01:35 PM
twleblanc
twleblanc's Avatar
Just put the top down! ;-)
Old 11-15-14, 11:18 AM
13IS250C
13IS250C's Avatar
I did until the temps dropped into the 30s
ExclusivIS
IS F (2008-2014)
22
03-23-20 09:36 PM
LexusFan2
ES - 5th Gen (2007-2012)
06-28-16 08:49 PM
schulzd
11-18-14 08:07 PM
DaveJ
07-25-05 04:17 PM
rxdriver
05-14-04 07:32 PM
Quick Reply: Rear deck rattle with top up - TSB?
