IS C Discussion about the convertible IS C model
Oil change question
Old 05-08-12, 04:53 PM
freeflight
freeflight's Avatar
Default Oil change question
I need to get 2nd oil change for my IS 250C. The annual mileage for the car is about 5K miles. I take it easy driving these day. Engine runs at 2-3K RPM most of the time, and only hits 4K RPM when merging onto freeway. I plan to change oil once per year. Which kind of oil is better for me, synthetic or conventional?
Thanks,
Kevin
Old 05-08-12, 05:19 PM
ISCjonny
ISCjonny's Avatar
Well it sounds like you dont drive your car much. I would go with a full synthetic since it doesnt decompose as fast. You could probably get away with changing it once a year.. but i would recommend once every 6 months. ENEOS 5w30 Full Synthetic is a great oil. I use it everytime.
Old 05-08-12, 06:17 PM
Dawa
Dawa's Avatar
wow 5k a year that is crazy. +1 for synthetic.
Old 05-08-12, 06:41 PM
freeflight
freeflight's Avatar
Oh well, I guess I will drive it more. With the current high gas price, it actually saves money by driving the convertible than the SUV. Now if I drive 10K per year, would synthetic offer any tangible benefits over dino?
I always thought synthetic is for cars get driven hard.
Old 05-09-12, 01:22 AM
ISCjonny
ISCjonny's Avatar
synthetics tend to have better lube, heat dissipation, and can withstand a wider range of heat without breaking down compared to Dino. I guess you can say thats why people recommend synthetics if you drive hard. In the end, synthetic vs dino all have the same basic additives. So its up to you to choose what makes you sleep better at night.
Old 05-09-12, 09:06 AM
Kurtz
Kurtz's Avatar
It really depends on how you're using it.
For low-miles-driven cars the difference is this:
If it's low miles driven because you only ever take trips that are 1-5 miles one way, the car never gets to run at operating temp and burn off all the crap in the oil... this is considered severe duty service, even if you never drive it "hard"
If that's you then change it every 3 months, regardless of miles, with the cheapest oil you can find of the proper weight. That type of driving is terrible for oil. (so is excessive idling, double trouble if that 1-5 miles involves all stop -n-go with traffic and long lights)
If it's low miles because you only drive it 1-2 times a week, but do so on a 30-miles-each-way trip somewhere on the highway, then change it once a year with any decent synthetic and don't worry about it.
Old 05-09-12, 12:53 PM
freeflight
freeflight's Avatar
Hi Kurtz,
Thanks for your very informative reply. It looks like I need to change oil more often on the SUV, which follows the severe schedule. The convertible has mostly freeway miles, so any oil is probably okay for that matter. But I know the 250 engine has carbon built-up problem. Do you think use synthetic oil would help prevent it?
Kevin
Old 05-09-12, 12:57 PM
mkorsu
Zombie Slayer
mkorsu's Avatar
Not to pick but how do you even merge onto a highway at 4k rpm?
Opening that engine up every once in a while will reduce any carbon build up you are worrying about.
Old 05-09-12, 03:38 PM
freeflight
freeflight's Avatar
Merging onto freeway is more of a judgement than speed, otherwise how can those Prius or Yaris merge onto freeway? I don't even need 4K RPM, 3K would have been fine.
Old 05-09-12, 03:41 PM
freeflight
freeflight's Avatar
Any explanation or evidence on running at higher RPM helps reduce carbon built-up?
Old 05-30-12, 08:04 PM
LDNN
LDNN's Avatar
+1. I would like to hear too!
Old 06-05-12, 08:30 PM
FNFZ4
FNFZ4's Avatar
oil is cheap. an engine isnt... why take the risk?
Old 06-07-12, 06:14 AM
Heckler
Heckler's Avatar
If you are running 5k a year I would change it every 6 months with synthetic oil. Even if the miles are stop and go traffic that is very few miles driven. I would not put cheap dino oil in, ever. *This is my opinion and not based on any scientific oil studies or lab testing*.
If you are set on doing it once per year I would still run synthetic.
Old 06-07-12, 10:12 AM
TLP_IS350
TLP_IS350's Avatar
^ +1. investing $30-40k in an automobile isnt cheap so why put dino cheap oil in it? Sure toyota motors are indestructible but why not make it invincible by changing the oil with some synthetic? i run synthetic in everything i own and my friends and family always compliment on how well my vehicles run. i mean if you arent hurting for money and a $30k-40k car is chump change then just put whatever oil you want in it. i always live by the rule, you pay for what you get, so i run synthetic all the way, preferably Mobil 1
Old 06-11-12, 12:04 PM
SC400MAN
SC400MAN's Avatar
My wife has an IS350 that she puts about that many miles on and I have the oil changed twice a year. I think that Lexus recommends every 5000 miles or 6 months, whichever comes first.
TrueGS300
06-25-23 01:30 PM
MellonC00
RX - 1st Gen (1999-2003)
02-25-19 11:10 AM
joshua777
08-08-18 01:39 PM
funcrusher
02-01-11 07:21 PM
818sc400
Performance & Maintenance
19
05-21-08 07:51 PM
Quick Reply: Oil change question
