Carbon Fiber Mirror Covers
Old 08-07-16, 09:53 PM
  #61
14is350
14is350's Avatar
Old 08-08-16, 09:16 AM
  #62
Phamkq
Phamkq's Avatar
Originally Posted by 14is350
ive heard both good and bad with hydro dipping. To each their own. I bet it would still turn out really nice.
Definitely, maybe because the market for hydrodipping is so limited so for those who run that business make that extra money (supply and demand). I can honestly say I swore I thought the carbon fiber I saw on my friends lip and spoiler was real carbon fiber until he told me it was hydrodipped.
Old 08-08-16, 09:48 AM
  #63
Cthan3o3
Cthan3o3's Avatar
Is hydrodipping reversible if u decided to sell your car later on?
Old 08-08-16, 10:21 AM
  #64
Phamkq
Phamkq's Avatar
From the best of my knowledge, I believe it isn't. But hey, good thing is that the cover will fit your mirrors perfectly since it's technically OEM
Old 08-10-16, 12:26 PM
  #65
Ray20213
Ray20213's Avatar
Default Wow
Just beautiful....
Old 04-04-17, 09:15 PM
  #66
rmreddy5
rmreddy5's Avatar
Did these have the adhesive already installed? Do you peel all the adhesive backing off before install or do you just peel partially to adjust?
Old 04-04-17, 11:20 PM
  #67
slickster9
slickster9's Avatar
the covers on ebay already have adhesive installed, but its usually not enough. I had to add some along the edges on the bottom and the top.
In my humble opinion it looks much better with the bottom neck wrapped as well, ill have to get this done as mine remains the stock color.
Old 04-05-17, 12:33 AM
  #68
FURAIBO
FURAIBO's Avatar
@rmreddy5: I'd suggest test-fitting the mirror covers without adhesive first. From what I understand these are handmade and therefore do not provide a 100% perfect fit.
In addition, the adhesive tape is not good enough to allow an adequate alignment - at least in my case. Polyurethane adhesive was applied to reassure the covers won't come off over time and black vinyl was used to cover the few edges where the CFRP covers didn't align properly (slight deviation, mentioned in this thread).
I agree with slickster9, to wrap the bottom neck of the mirrors unless you own a black IS. However, I wouldn't use that cheap looking "carbon trim" since it goes against the idea of using real CFRP parts for looks in the first place... Black vinyl or better yet black paint will do.
Old 04-05-17, 05:22 AM
  #69
rmreddy5
rmreddy5's Avatar
Thank you kind sir!
Old 06-09-17, 06:25 AM
  #70
truthbtold
truthbtold's Avatar
Originally Posted by Ray20213
Just beautiful....
How did you wrap the base? Did you have to remove it and if so how?
Old 06-10-17, 05:52 PM
  #71
jmull3r
jmull3r's Avatar
^^im curious too
16GSF00336
GS F (2016-present)
16
05-08-18 10:58 AM
SilvaIS350
06-11-15 05:16 AM
sarge5792
11-10-14 06:39 AM
MK4Sup_isF
IS F (2008-2014)
35
08-12-14 09:48 AM
Rock-a-Lex
10-29-12 10:52 AM
Quick Reply: Carbon Fiber Mirror Covers
