Headlights help!
Old 02-27-16, 07:13 PM
TrueDat96
TrueDat96's Avatar
Default Headlights help!
I recently got coilers installed, and tonight was the first time that i drove at night with them on. My headlights are point down and is not getting the distance that it use to have, can someone tell me how to adjust(preferably with pictures or videos) my headlight so that they are pointing more upwards? I thought I've seen a thread on how to do it but i can't find it anymore. I drive a 2014 is250
Old 02-27-16, 07:37 PM
brendanf
brendanf's Avatar
here you go:
https://www.clublexus.com/how-tos/a/...springs-362554
Old 02-27-16, 07:52 PM
Brokenis
Brokenis's Avatar
I had no idea you can adjust them this way...
This is how I did it:
Park car on level ground in front of a wall
Open the hood
Look behind each headlight, there will be a dial(The dial has triangular angles) that is visible when looking from above. The dial itself is in a pretty tight spot, you may also use a socket wrench but I found a screwdriver to be the easiest.
Use a long flathead screwdriver and turn the dial right for higher, left for lower...
Not sure if this method will cause any issues, but i've had it like this for a while and it's been a-okay.
Hope it helps.
Old 02-27-16, 08:39 PM
TrueDat96
TrueDat96's Avatar
Open the hood
Hope it helps.
Worked great, thanks so much!
Old 05-09-16, 12:00 AM
3ISRC
3ISRC's Avatar
Hi this method works perfectly. Do you guys remember how many turns to the right you had to do?
Old 05-09-16, 12:49 AM
leo877
leo877's Avatar
I have my car lowered on F sport springs but never thought about this before. I definitely try this tomorrow.
Old 05-09-16, 12:57 AM
ph0nzie
ph0nzie's Avatar
There is no exact number of turns. Just got to find a flat parking lot and aim your headlights at a wall. Turn until they both look like they are pointing straight across. And even on both left and right side.
Old 05-09-16, 02:33 AM
LexVu
LexVu's Avatar
all this time after having my coils installed ive been using my highbeams....
Old 05-09-16, 07:22 AM
3ISRC
3ISRC's Avatar
This should be a sticky of some sort lol. It's so easy to do that lowered IS should do immediately.
Old 05-11-16, 09:54 PM
leo877
leo877's Avatar
Open the hood
Hope it helps.
Are these the dials you mentioned?
Old 05-15-16, 12:37 AM
3ISRC
3ISRC's Avatar
Yes that's the one. Now you can't really adjust the plastic dial. Instead, use a flat head and adjust from the top. It's the ones that looks like small cones.
Old 05-15-16, 11:00 AM
EJ255t
EJ255t's Avatar
when i lowered my car, my lights leveled by themselves. I have the LED's, got my car back and turned it on, and the lights leveled themselves. didnt know the LED's headlights did that
Old 05-15-16, 12:16 PM
AdvanSLF
AdvanSLF's Avatar
The LEDs do not have auto leveling. The HIDs do I believe, but not the LEDs. This has been a common discussion and misconception that LEDs have auto leveling. Hence why there is a thread for LED owners to manually adjust it themselves.
Old 05-15-16, 09:19 PM
ARM350F
ARM350F's Avatar
By auto leveling do you mean up and down movement if so then I can assure you that my car has this feature.
Old 05-16-16, 06:34 AM
KYLESTONES
KYLESTONES's Avatar
When I first put my headlights on after lowering on RSR downs I was up against my garage and physically watched the headlights adjust (2015 with LED headlights). Ever since, they do not do it. Now I'm not saying they have that feature or not as I'm not positive but I can say I did witness them adjusting
Quick Reply: Headlights help!
