LED turn signal question
I wanted to get rid of the amber in the headlight as well as match the colors of the lights up front (why I got white instead of Amber) and I didn't feel it's necessary for the rear.. Maybe I'll get them down the line but for now just the front is fine with me. Also I don't know where I would mount the resistor in the taillights
I purchased a full LED setup from VLEDS (Front/Rear turn signals, reverse lights, trunk light, courtesy door lights, vanity lights, outside mirror puddle lights, foot well lights and front/rear interior dome lights). All of them fit perfectly and without any issues!
The most notable are my turn signals, the V3 Triton series that they carry. They are hands down the best and brightest that I've ever used. They do include a ballast, which is the only reason I haven't swapped out my rear signals yet as there's virtually no room unless I mount it inside the rear bumper.
These are the ones I'm using: V3 Triton Amber LED Switchback System
I can post pictures if you'd like to see them lit up.
Just a heads up...
The CREE from iJDMToy are very nice, and fit just fine in the front...but they will NOT fit the rears. I know because I bought all 4 to do front and rear and the bulbs for the rear are too long and won't clear the housing and lock into place.
Don't waste time and money buying those specific bulbs for the rear. I personally am seeking an error free bulb that will fit. Just tried another one that had a shorter length but of course, they were too fat!
Still on the hunt!
Still on the hunt!
Just a heads up...
Still on the hunt!
Still on the hunt!
Bulb was too long by a mm or 2... The end of the bulb hits the plastic just enough so they can't twist and lock.
Just received my LEDs in the mail today and was attempting to see if they fit in the rear turn signals. It was the first time attempting to look at it and I wasn't sure do I need to remove the bumper to do this?
just received mine in the mail and did a quick install.. i purchased 2 sets and they DO fit in the rear turn signals. these are my before and after pictures of the fronts
That's the before and after. My install was kinda sloppy because I was in a rush to get to work but i ended up placing the rectangular decoder on the inside of the metal body but behind the lining of the trunk. I fed both the connector to the socket and the bulb itself through the rubber grommet hole (the grommet isn't in the hole it's kinda just there outside of the hole). I'll eventually make it cleaner by making big enough holes to feed both connectors through it but i was on a time crunch
Cconnors, which bulbs did you go with? The CREE bulbs I referenced that do not fit do not use a decoder... I'm guessing you went with the bulbs from VLED's?
I was looking for a plug and play bulb that would fit...no resistor, no decoder, etc.. The CREE bulbs were too long.
Please clarify where you got your bulbs and decoder
