Tire and Wheel Setup - 19x9 +35 and 19x10.5 +45
Been reading through build and wheel threads to confirm whether or not this setup will rub on RSR Downs.
Fronts: 19x9 +35 with 225/30/19
Rears: 19x10.5 +45 with 265/30/19
Would this setup be flush? and will it rub?
Sorry if this question has been posted before
The pursuit of F
Did you mean 265 at the rear?
It will likely rub with 265s. Consider a slightly more stretched tire (245s) at the rear if you want to keep the wider rims and avoid rubbing.
i have that exact same setup!! no rubbing at all. if you run a 275/30/19 you still wont rub unless you load your car or hit a big enough bump.
for the fronts you can actually go 245/35 with no issues.
im running :
245/35/19---front
265/30/19---rear
NO RUBBING!!
im running :
245/35/19---front
265/30/19---rear
NO RUBBING!!
It probably won't rub if you don't have rear passengers and a full tank of gas lol but I know somebody with 19x10 et40 and it rubs with ppl in the back or moderate dips...so it depends if you can live with that
I find this hard to believe, are you sure you have a 19x10.5 with a +40mm offset? With a 265/30 on there I can't believe it won't rub with RSR downs.
ok, just caught the mistake, OP posted thread Tire and Wheel Setup - 19x9 +35 and 19x10.5 +45, but on this first post he posted 19x9+35///19x10.5+40.....??
but anyways, im running
19x9+35 front-----19x10.5+45 rear
235/35/19 front
265/30/19 rear
Continental DW
RSR down springs no rubbing
im going to try and test fit 275/30/19 in the rears on my next set, that will be a tight fit.
235/35/19 front
265/30/19 rear
Continental DW
235/35/19 front
265/30/19 rear
Continental DW
235/35/19 front
265/30/19 rear
Continental DW
