Square Wheel Setup
Square Wheel Setup
3IS isn't a track performance car, but it's fun to take those corners, with skill and speed.
With that being said, anyone here running a square setup? List wheel/tire specs, and post pics if you can.
I'm planning to run 18x9.5f et30, 18x9.5r et38 on a 265 tire, although debating if 255 is too stretched, depends on the tire I guess... Any input?
Anyone know how anyone know if 18x10 will fit in the front?
4Infiniti (07-21-20)
18x8.5 +38 square set up, stock tire specs (225/40 & 255/35). Dropped on coilovers. No rubbing. I went ultra conservative so I don't have to worry at all with rubbing.
Could've gone with 18x9.5 in the rear with no problems. The 255 tire would fit nicely on 9.5. Theres a bit of tire 255 on the 8.5.
18x9.5 in the front would be a moderate fit and might rub in the front. 18x10 would definitely be aggressive.
I've heard of a few of our customers use 8.5 ET35 + 255 without any issue. A bit conservative, but does the job. Another option is 9.5 ET33 (our specs) + 255 (most likely require some modification). 255 on 9.5 is really not a stretch, though, this can vary depending on what tire brand/model you go with.
Didn't want to start a new thread
Anyone running 18x8.5 with 255-35-18 all around?
Noob question along with it, it won't drastically change the the car's behavior would it?
