Heated Seat Discussion (merged threads)
Old 09-27-13, 08:29 AM
dojoman
dojoman's Avatar
Exclamation Heated Seat Discussion (merged threads)
I just noticed this today... Before driving I turned on the heated seat to two dots position (medium), but then after driving for about 20min the setting changed to one dot (low) by itself.
Is this a problem with the seat heater or not sure if it was normal?
Old 09-27-13, 08:45 AM
jhs82
jhs82's Avatar
That's normal. It works on a timer.
Old 09-27-13, 08:58 AM
dojoman
dojoman's Avatar
Anyway to keep it on without going to lower setting by itself?
Old 09-27-13, 09:03 AM
jhs82
jhs82's Avatar
Don't know. Check the setup menus.
Old 09-27-13, 09:25 AM
grondie
Merkur Fanatic
grondie's Avatar
With the car in accessory mode, hold down both heater switches (driver / pass) until you hear a beep. This disables the timer "feature"
Old 09-27-13, 10:04 AM
redraptor
redraptor's Avatar
I tried it today and it works. Thanks
Posted from ClubLexus.com App for Android
Old 09-27-13, 10:06 AM
dojoman
dojoman's Avatar
Awesome thanks a bunch!!!
Old 11-02-13, 06:49 PM
hoosier1
hoosier1's Avatar
I also noticed that the heated and cooled seat function remains on even if you stop and restart the car. On my BMW, the heated seats automatically cancelled after turning the car off.
Old 11-02-13, 07:03 PM
dbs600
dbs600's Avatar
They remain on on my BMW, a 2011 750...
Old 11-02-13, 09:36 PM
dbs600
dbs600's Avatar
Tried this and it wasn't working in Accessory Mode.
Opened the manual, which mentions same, but didn't state in what mode.
Started the engine and tried again, which worked!
Unfortunately, the heated seats are STILL very weak.
Any way to increase the temperature of same?
Thanks.
Old 11-03-13, 09:45 AM
js1011
js1011's Avatar
Heat seats work great, but I can see it being helpful if it stayed at 3 (if you will) for the colder states. In California, you can get away with keeping the heated seat at one without turning on the heater in the coldest day, suckas!
Old 11-03-13, 09:47 AM
Defratos
Defratos's Avatar
Since were on the topic of seat heaters,
Does anyone know if there's a way to change the seat heater to a seat cooler/chiller instead?
Old 11-03-13, 03:57 PM
dbs600
dbs600's Avatar
Originally Posted by js1011
Heat seats work great...
Do yours get hot or just very warm?
Your seats are get too hot!?
Old 11-03-13, 05:03 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
I turned my heated seats on for the first time (level 3) for a 15 minute drive and was warm at best.
Anyone else find the heat lacking?
Old 11-03-13, 05:19 PM
JDR76
JDR76's Avatar
Received 1,604 Likes on 1,022 Posts
Not me. Mine cook. I can only use the lowest setting or I am way too warm.
Quick Reply: Heated Seat Discussion (merged threads)
