2006 is350 (Neutral acts like ignition button )
Old 02-01-17, 02:10 PM
Galeh
Galeh's Avatar
Default 2006 is350 (Neutral acts like ignition button )
hi there
i just get a 2006 Lexus IS350 with 86k mikes from auction ( I don't know about the exact history of car except carfox report), everything works in order except whenever the engine is on and trying to move the shifter lever and pass the Neutral to go to Drive mode , the engine shuts off, but if I put it in the Neutral again it will run and the starter will not stop till put it in R or D
it seems to me that the NEUTRAL Acts like ignition button
car shifts smooth and don't Ave any issue with transmission
is there anything wrong with Neutral safety switch or wiring?!
Please help
Old 02-01-17, 02:12 PM
yardie876
yardie876's Avatar
A video of this behavior would be great, because this is about the oddest issue I've heard of.
Old 02-01-17, 02:19 PM
Viktimize
Viktimize's Avatar
Wow that is weird. There is no neutral safety switch in an automatic. But it seems that you have some sort of short between your transmission wiring and the starter relay circuit. First thing I would try to do is start tracing out the wiring from the starter solenoid and see if you can find somewhere it is rubbing or pinched against something.
Old 02-01-17, 02:21 PM
Galeh
Galeh's Avatar
very simple
car starts in P without any issue,
in R runs and drives perfect
the trouble starts whenever I want to pass N or stay in N ( engine shuts off and with start button doesn't work in N)
shifting back in N will start the engine and keep STARTER working till put in in other gear (R or D)
Old 02-01-17, 02:22 PM
Galeh
Galeh's Avatar
great
im gonna check it today and keep u tuned
Old 02-01-17, 07:28 PM
Galeh
Galeh's Avatar
Originally Posted by Galeh
great
I jacked it up it Has Neutral safety switch
Old 02-01-17, 11:16 PM
Viktimize
Viktimize's Avatar
Well maybe that's your issue then, a short in that switch. I'd just get the 2 day TIS subscription to look at the wiring diagrams and confirm.
Old 02-02-17, 11:37 AM
Galeh
Galeh's Avatar
I took out the Neutral Safety Switch (NSS) , there were bunch of oxidation and rust on connector, I cleaned it up put it back , runned the engine, something changed
now it turn on and off simultaneously in N
check engine poped up
I am gonna get new or used one to replace it
Old 02-02-17, 06:56 PM
Viktimize
Viktimize's Avatar
I'd be interested to hear what code it threw as well.
Old 02-02-17, 08:54 PM
Galeh
Galeh's Avatar
I'll let u know about the code
bbatman
03-10-18 05:32 PM
Jwebster87
05-10-17 03:08 PM
mandyfig
09-03-13 02:06 PM
fishguy55
10-17-11 08:17 AM
Lexus082
SC- 1st Gen (1992-2000)
05-06-11 09:22 PM
Quick Reply: 2006 is350 (Neutral acts like ignition button )
