2006 is350 headlight bulb question?
Okay so I need to know what bulb to buy for my low beam headlights. I see that there are two different ones. One is the H11 and one is the D4S. I have a HID kit in there now but the shop is saying that is why my headlight is getting water condensation in it so I want to buy stock bulbs to get it back to stock and see if it still gets condensation. Below are are links to the two different bulbs but I am not sure which one is the correct one.
D4S bulb
http://www.ebay.com/itm/NEW-GENUINE-...VX~b7Z&vxp=mtr
H11 bulb
http://www.ebay.com/itm/2x-5000K-Whi...5XNn9d&vxp=mtr
Also will this led kit work as in fit the plugs and be able to put the plastic cover on behind the headlight so that it will be sealed tight? Or will I have to use the D4S bulb?
http://www.ebay.com/itm/80W-8000LM-P...BYIb5S&vxp=mtr
D4S bulb
H11 bulb
Well since you have an hid kit u want the bulb that goes with that kit, not sure which kit u have so I can't tell u which bulb. Since u have a hid kit I'm assuming u have stock hologen lights which means ur looking for the h11 bulb but then u cannot use the kit and the light will be yellow and not white but it'll be oem.
thank you. I am just going to get the cheapest thing I can find as this is only to test if the head will still get water condensation or not with the back bulb cover on.
jashtiani
11-10-15 06:50 PM
