Instrument cluster noise on start up?
Old 07-03-16, 11:32 AM
flektone
flektone's Avatar
Default Instrument cluster noise on start up?
Anyone ever experience noise coming from or behind the instrument cluster? Its hard to describe and im trying to capture video but its hard to hear. Its like a brief static sound is the best way i can describe it. I started it up several times with the hood open and its definitely NOT coming from the engine. I have my dash replaced about 3 months ago and just started hearing this sound about 3 weeks ago. Maybe something wasnt put back correctly?
Old 07-04-16, 04:39 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I hope you're not talking about the steering wheel alignment that makes a noise before you start the car, and after the car is shut off and a door is opened.
Old 07-04-16, 04:53 PM
sktn77a
sktn77a's Avatar
^^^ Yes, I think you're talking about the steering wheel lock. It's a grinding sort of noise.
Old 07-05-16, 04:21 AM
HankMoody
HankMoody's Avatar
I think what you're hearing is the needle wipe that occurs when you push the start button.
Old 07-05-16, 05:48 AM
flektone
flektone's Avatar
I found one other post on here. Looks like its something within the cluster. I thought maybe something wasnt put back right after my dash was replaced. Doesnt seem like a big deal. If my cluster craps out I can just buy another off ebay and follow the youtube video on how to replace.
Old 07-05-16, 06:20 AM
Bkhectic
Bkhectic's Avatar
I also just started hearing the grinding sound when I turn the ignition on and the needle moves. It's definitely the needle because I tried it without starting the car. Anyone knows what this is?
Old 07-05-16, 08:09 AM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
Someone should really shoot a video, or at least a sound clip. Without hearing it, I can't help but suspect that it's the steering lock mechanism unlocking.
Old 07-07-16, 04:38 AM
HankMoody
HankMoody's Avatar
I mean, I can definitely hear the needles move in mine, but it's not loud by any means.. Is it a constant noise ? or just when pushing the ign button ?
Old 07-07-16, 04:55 AM
flektone
flektone's Avatar
Just on start up. My main concern was if it was engine related or not. Do a search and youll find another post with several people complaining of the same thing. It appears there is an issue with the instrument cluster. Its an easy fix so im not to worried about it.
My next question is if you swap out the cluster from one off ebay how do you track the mileage? Can the dealer reprogram with the proper mileage?
Old 07-07-16, 05:17 AM
HankMoody
HankMoody's Avatar
So the instrument cluster is bad ?
Old 07-07-16, 05:50 AM
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
Hi, Tanin Auto Electronix here. We are vendors on the site and can offer some assistance. We not only fix clusters but also reprogram mileage into vehicles. Here is the link to that service:
http://www.taninautoelectronix.com/S...do_correct.htm
Let us know if you have any questions at all and if you aren't able to fix the cluster. We can always check it out and if it is not repairable, we can locate a new one for you as well.
Feel free to contact us any time.
Thanks,
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
flektone
flektone's Avatar
I guess so. In the other post people said they have gotten them replaced under warranty. I am a little annoyed buy some of the cheap crap in this car. Stupid things like the NAV touch screen to instrument cluster issues should not happen with a Toyota/Lexus. Id expext that from a VW.
Old 07-09-16, 07:33 AM
sktn77a
sktn77a's Avatar
If you're not going to post a video of the noise then take it to the dealer for a quick diagnosis. The service writer can listen and tell you for no charge if it's just the steering wheel lock. If it's not, then you can go about tearing out the cluster and replacing it.
Old 07-09-16, 08:44 PM
flektone
flektone's Avatar
It is the cluster. I tried what another poster said and turned the car on without the engine. The sound its coming from the speedometer needles. Not a big deal. If/when it craps out ill replace it.
Old 07-10-16, 07:23 AM
HankMoody
HankMoody's Avatar
How long does the noise last ?
Quick Reply: Instrument cluster noise on start up?
