Enkei Raijin
10th Gear
Enkei Raijin
Can someone confirm if these will fit an IS350 without any modifications (fender roll, pulled, etc) before I get them? Thanks in advance
18x8.0 40MM Offset
18x9.5 35MM Offset
18x8.0 40MM Offset
18x9.5 35MM Offset
Forum Administrator
Have you confirmed that they are high disc to clear your front brakes?
Did you look at the will these wheels fit link in the FAQ?
10th Gear
I'm not doing anything crazy with the tire size, probably 235 up front and 255 rear. I'm more concern about the front not clearing the brakes.
I don't know about high/low disk.
yoitskenn
12
11-06-12 06:29 PM
Gernby
Wheels, Tires & Brakes Forum
13
04-13-07 03:00 PM
