help [Will my car pass a smog check with only a Joe z intake? ?]
Old 02-11-16, 08:55 AM
blkout250
blkout250's Avatar
Default help [Will my car pass a smog check with only a Joe z intake? ?]
Old 02-11-16, 09:48 AM
Ktran1039
Ktran1039's Avatar
Yes, same as fsport basically.
I have joez with lower intake box holes
Passed last week
Old 02-11-16, 10:00 AM
blkout250
blkout250's Avatar
Thanks
QUOTE=Ktran1039;9362067]Yes, same as fsport basically.
Passed last week[/QUOTE]
Old 02-11-16, 12:23 PM
flowrider
flowrider's Avatar
Received 1,949 Likes on 1,372 Posts
In California, the JoeZ intake does not have a Carb approved sticker. So technically it should not pass visual. However, the inspector may look the other way.
Lou
Old 02-11-16, 08:29 PM
A1cntrler
A1cntrler's Avatar
The emissions station I've always used does a visual check and requires there to be a CARB sticker with a number on it. They have to look it up on a DMV system to see that is it approved for use on that model car (It may fit/be identical to a 2007, but if it's on a 2006 and 2006 isn't on the list you're not passing). There's no gray area from what he told me. If it's on the CARB list it's ok.
I have the F Sport intake on mine, and he needed to see the sticker stating it was CARB approved. Luckily I did put the sticker on it. He did charge extra to smog it because it was a modified vehicle and the extra time required to search the database to make sure it was legal in CA on my vehicle.
I'd recommend to swap it with a factory box for your inspection. IT takes like 15 minutes to do the swap and will save you time and stress hoping they will pass it.
Old 02-11-16, 08:39 PM
projectdna
projectdna's Avatar
https://www.clublexus.com/forums/per...on-thread.html
most CA 2is owners have more than just the Joe Z intake, and all they did was drive to their nearest smog testing facility and pass. YMMV, but the inspector would have to be a hardliner to fail you for *just* a Joe Z intake.
Old 02-12-16, 07:20 PM
liqB
liqB's Avatar
You can go to the dealership, and say you misplaced your carb sticker for an f-sport intake.
Old 02-13-16, 03:17 AM
Ktran1039
Ktran1039's Avatar
I told them i got a second hand f sport intake and needed a new sticker. It worked out
Old 02-13-16, 09:32 AM
flowrider
flowrider's Avatar
^^^^And you didn't mention this in you post #2 above
Lou
Old 02-14-16, 09:11 AM
Ktran1039
Ktran1039's Avatar
Lou
Completely slipped my mind until Someone mentioned carb stickers.
Granted when I got a smog check I dont think he even looked for the carb sticker. I have a Joez but the 1st gen so its a dark grey matte color. Looks completely stock.
I went and got a carb sticker from dealership just in case though. Got it for free. Chick behind the counter just handed me one like a piece of candy.
Old 02-14-16, 09:24 AM
whitebeast
whitebeast's Avatar
My F-Sport intake it good and pass smog without any problem (ofcourse no Card)
Tro209
10-03-15 09:39 AM
Silec
09-03-13 01:47 PM
Madog350
Performance
04-19-12 08:53 AM
dotkong
Performance
10-16-08 09:51 PM
Quick Reply: help [Will my car pass a smog check with only a Joe z intake? ?]
