Two weeks still can't find the problem
Hi,
My 2008 IS 250 has a problem, at a mere distance of 37k. One morning before I got to work I started the engine and noticed the master warning light, malfunction and slip lights are on; as well as a "check vsc" message on the screen, which lead to me to turn off the engine immediately.
After explaining the issue to a Sydney Lexus service center (distributor), I had them tow my car 3 days later. A few days later I received a call form the service center which stated that the alternator must be replaced as it is malfunctioning, and after it was replaced the car functioned normally for a short while before the gearbox begun malfunctioning.
The car has been in the Lexus service center for two weeks and they still can't find the problem
Would someone be able to do something about this issue?
Hi,
might be one of the sensors. had a coworker have a VSC check light turn on after the fuel pressure sensor was changed, turned out to be the same fuel pressure sensor. but it could be anything
whenever i see VSC i think of gas caps.. however that isnt the fix alot of times. but it is worth a shot to buy a new OEM gas cap before you spend alot of money. one time all kinds of warnings popped up, and that was my culprit cuz it wasn't on tight enough.
Hi,
Super Moderator
I disagree. Sure, check the gas cap to make sure it is on tight because it is easy and free. But honestly, the very first thing you should do when the check engine and check VSC come on are to read the diagnostic trouble codes. AutoZone and some other parts stores will do this for free. If you don't live close to one, you can buy a very basic OBD2 scan tool (capable of reading and clearing codes) on Amazon for $20-30. It makes no sense to replace the gas cap unless the codes read indicate an evaporate emissions leak.
Four errors have been detected by the Lexus dealer service centre:
- ECT transmission range sensor
ABS- Engine control malfunction
Power control source
P Signal does not match bean infro.
No code numbers have been issued. As a result, replacing the alternator resulted in the warning lights being switched off. However, another issue was discovered with the gearbox after a week of full examination. They discovered that it short circuited and the junction box touches the body of the car.
With the odometer reading only 37k, why does the alternator malfunction after such a small distance or as a result of a junction box short circuit?
Sp77641
GX - 2nd Gen (2010-2023)
01-20-15 06:51 AM
