Bc Coilovers.. how does dampening work?
Okay so im probably gonna have my Coils installed today or if not maybe this Friday the latest. My question is regarding the dampening settings.
If i have my coils installed with lets say an example of 20 clicks to stiff up front and 20 clicks out back, will I be able to change the setting easily afterwards if i dont like it??
Or would this require removing the coilovers all over again? Im pretty confused on how this works at the moment as I have never had Coilovers on a car before. Lol
Thanks everyone .
Also, i have the standard 10k/8k spring rates. What would be idle for dropping my car to have Zero wheel gap (or less lol) and not hitting the ground when i go over bumps? Or is this not possible with these springs??
Thanks everyone .
No, you don't have to remove the coils again to adjust the dampening. Front adjustments are super easy to get to as it's visible when you open the hood. Rears however, to easily access the adjustment, you would need extenders through the trunk liner or you could set it to your liking before reassembling.
Thats what i was noticing today when looking at how to install these... the dampener should be right under that trunk liner right? Which means i dont need to buy extenders?
this is probably the way easier option though...
Well yes i agree their nice and all but are they necessary? Could i just do what allan1 said about removing the trunk liner? It should be right there correct?
What are your settings if you dont mind me asking Gville350? I was recommened to just go close to max stiff by a friend (since i will going quite low lol) but i definitely dont wanna lose my ability to hook up off the line either :/
Well it's not necessary but it's convenient to have. Every time I want to adjust it have to remove the center portion of the liner and the 2 metal loops just to peel back the sides far enough to see the tops. Kinda regret not getting them with the "free" extenders sale.
Since it's now getting cold here in SC, I've lowered everything. Now 18 clicks up from full soft up front and 15 in the rear. In summer time weather, I've ran 22 up front and 18 in the rear. I'm running 12k up front and 8k in the rear. No longer slammed...but definitely LOW. Running 19s.
So now i set the front to 24/30 clicks to stiff and the rear to 20/30 to stiff and i LOVE the way it feels now.
Cool thanks for the info. I just installed them today and lowered the car to a 2 finger gap up front and no gap (slight tire tuck) in the rear. I also had them set the coils to 18 (towards stiff) for both the front and rear and decided i didnt like it.
