2011 IS350 Car Won't Turn Over
Old 10-31-15, 07:12 PM
nfordhk
nfordhk's Avatar
Default 2011 IS350 Car Won't Turn Over
Hi,
Drove around the car all day with no issues. Just went out to start it and it will not turn over. Car definitely has power, and acts like it's going to start but just doesn't fire up.
I checked all the fuses and tried to jump it too.
No idea here. Seems as if the car isn't getting spark or fuel .
Way to ruin my Halloween
Old 10-31-15, 08:08 PM
Bichon
Super Moderator
Bichon's Avatar
Try starting the car with the gas pedal fully depressed. It won't work if the car isn't getting spark or fuel, but it should help if the engine is flooded.
Old 10-31-15, 10:21 PM
MWIS350
MWIS350's Avatar
Have you check the battery?
Old 11-01-15, 04:12 AM
Shervin350
Shervin350's Avatar
our cars are power hungry, i had a battery thats was a year old and it failed, everything turned on except the car, put a new battery in
Old 11-01-15, 05:07 AM
Bichon
Super Moderator
Bichon's Avatar
He said that he tried jumping the car without success. Also, I assumed that he meant that the engine wouldn't catch, not that it wouldn't turn over, since he said that it acted like it wasn't getting spark or fuel.
Old 11-01-15, 09:08 AM
nfordhk
nfordhk's Avatar
Car fired up this morning without hesitation. Didn't change anything. Looks like I'll have to keep an eye on it.
@Bichon, you're right sorry for the confusing wording. The engine just wouldn't catch.
Old 11-02-15, 02:22 PM
Gville350
Gville350's Avatar
Oh boy, sounds like an electrical gremlin...those are the worst! Start by checking the batteries ground wire making sure it is secured to the chassis well.
Old 11-02-15, 03:31 PM
MWIS350
MWIS350's Avatar
Try Seaform fuel injectors cleaner in gas tank.
Old 11-03-15, 05:05 PM
whitebeast
whitebeast's Avatar
+1 for checking Grounding
Old 11-03-15, 06:38 PM
Bichon
Super Moderator
Bichon's Avatar
If it were a bad ground wire, the car wouldn't crank. The OP's car cranked fine, it just wouldn't start.
Old 11-07-15, 08:22 AM
nfordhk
nfordhk's Avatar
Thanks for all the comments, turned out to by my integration relay. It wasn't communicating with the fuel pump
Old 11-07-15, 01:30 PM
srt1
srt1's Avatar
Electrical causing fuel issues, damn relays.
Old 11-07-15, 02:05 PM
MWIS350
MWIS350's Avatar
How much will it cause to fixed something like that?
Old 11-07-15, 02:38 PM
nfordhk
nfordhk's Avatar
I had Lexus do it, took them 2 days to figure out what was causing it.
About 580 total. 200 for the part, rest was labor/tax.
I'd have to look at my work order to see how much of that was diagnostic fee and labor checking other components. I don't think it took them too long to actually install the part once they figured it out.
Old 11-07-15, 09:58 PM
MWIS350
MWIS350's Avatar
Diagnostic is about $65 and labor about $200 an hour.
Quick Reply: 2011 IS350 Car Won't Turn Over
