Third Brake Light Delete
Old 08-30-15, 10:01 PM
RyPeredo
RyPeredo's Avatar
Default Third Brake Light Delete
Is there any covers that are sold to go in place of the third(high mount) brake light?
My brake light rattles way to much from my sub. now I just want to take it off and be done with it.
Old 08-31-15, 08:49 AM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
This is something I certainly wouldn't do:
http://forums.officer.com/forums/arc...p/t-26723.html
Lou
Old 08-31-15, 10:52 AM
nfordhk
nfordhk's Avatar
I'd recommend highly against that
Old 09-01-15, 11:55 AM
Gville350
Gville350's Avatar
Think of something more creative than just removing the third brake light. Definitely illegal to run without one.
Old 09-01-15, 12:01 PM
SebaPR
SebaPR's Avatar
Who cares if its illegal its dangerous to you and your awesome ride. Most distracted people notice you brake because of the third brake light and not the other lights also since its a low car higher suvs/trucks only notice this light too.
solution: try using some deadening material on the underside and surrounding areas near the light like dynomat or whatever brand you like, the aluminium mats sold at home depot for sealing roofs or whatever work too search a little to make sure which to get exactly.
You can also look around on the underside to see if there is some way to screw it down and make it firmer some how.
If you find solution other than removal post it here, im getting my 15inch sub installed soon and prob will run into same prob as you.
Old 09-03-15, 08:07 PM
UniSlayEX
UniSlayEX's Avatar
According to Revised Code of Washington (RCW) 46.37.070(3) :
Originally Posted by RCW 46.37.070
Stop lamps and electric turn signals required.
(3) Every passenger car manufactured or assembled after September 1, 1985; and every passenger truck, passenger van, or passenger sports [sport] utility vehicle manufactured or assembled after September 1, 1993, must be equipped with a rear center high-mounted stop lamp meeting the requirements of RCW 46.37.200(3).
w/ respect to RCW 46.37.200(3) :
Originally Posted by RCW 46.37.200
(3) Any vehicle may be equipped and when required under this chapter shall be equipped with a center high-mounted stop lamp mounted on the center line of the rear of the vehicle. These stop lamps shall display a red light visible from a distance of not less than three hundred feet to the rear in normal sunlight, and shall be actuated upon application of a service brake, and may not be incorporated with any other rear lamps.
Do your own homework . . .
If your center brake light is rattling, take it to your nearest Lexus Service Center and have them repair it. In this case it would be a simple fix they may not charge you for. If they do decide to charge you, you're better off installing the foam yourself.
Old 09-04-15, 11:06 AM
dyongg
dyongg's Avatar
Sounds like the problem is from his sub and not something that's broken so he'll probably have to install foam.
To OP: Highly recommend NOT to "delete" your third brake light. Some people may not be able to tell when you're braking at night!
Old 09-04-15, 02:45 PM
RyPeredo
RyPeredo's Avatar
I'm not completely removing the third brake light. More like relocating it to a high mount. Just want to cover up the existing spot
Old 09-05-15, 12:08 AM
GiantsFan
GiantsFan's Avatar
I'd say it'll be easier to just secure it down... I think it's just clipped in there?
Old 09-05-15, 08:51 AM
VTsuckah
VTsuckah's Avatar
Or install dynamat extreme in the entire trunk area to minimize the vibration from the bass.
Old 09-05-15, 10:57 AM
RyPeredo
RyPeredo's Avatar
I've tried both. Securing it down and dynamat. Still some rattling Goin on
uplusd
04-05-07 10:06 PM
gsfor
02-06-05 03:48 PM
ES300SD
03-04-02 11:23 AM
Quick Reply: Third Brake Light Delete
