stud clearence using 5mm Spacer
VERY good point. The OE lug is a shank style with a washer and does go much further into the wheel than the conical seat nuts that are almost always used with aftermarket wheels. With that said, with 25.4mm in an inch, you are essentially talking about a spacer that is .2", which is pretty small.
i guess i should be more specific.
I'm planning on putting on my rear Big Brake Kit with a 5mm spacer because the spoke of the wheel hit the caliper during my last test fit...
I got the Project Mu acorn style lug nuts and im hoping I have enough thread on the stock studs..
