Need help with offsets for wheels
Old 05-26-15, 06:19 PM
Deathrow23
Deathrow23's Avatar
Default Need help with offsets for wheels
Purchasing work vs-xx step lips 19" . It was recommend by vendor for flush setup 19x9.5 22 and 19x10.5 22. Looking at some pics and threads, that may be too aggressive for me, as I want flush and some poke but not much. I was thinking 19x9 34 and 19x10.5 39 instead. I have rolled fender rears and fronts on coils. Can someone confirm this for me? Thanks.
Old 05-26-15, 06:40 PM
VTsuckah
VTsuckah's Avatar
The vender quoted offsets are very aggressive and likely would need a stretched tired, a good amount of camber, and a fender roll. 19x9 +35 & 19x10.5 +45 provides a nice flush look without tire stretch, fender mods and camber if you have decent drop. So you're on the right track if you want a little poke.
Old 05-27-15, 10:57 AM
Keo
Keo's Avatar
+22 is mild aggressive. People run that setup with minor fender roll. I almost got that setup. I know someone running +28 all around and it sits very clean no poke but not flush. Anything higher offset of +35 will look funny how itll tuck inside the fender more, especially if your going to lower on coils. Yes you do need to stretch tires. But only minor stretch. 225/35/19 - 235/35/19
Old 05-27-15, 11:16 AM
Deathrow23
Deathrow23's Avatar
so this is the setup that i have on order.
19x9.0 +34mm R Disk Front
19x10.5 +32mm A disk Rear
should that be good?
also, looking at the work wheel site. they have the O disk 10.5 + 39 as 87mm rim depth and also have the A disk 10.5 + 32mm as 87mm rim depth. would that be the same lip size?
Old 05-27-15, 06:31 PM
Slammer1
Slammer1's Avatar
Whatever you do, be sure to "test fit" your wheels for fitment before mounting the tires and virtually no wheel manufacturer accepts returns of wheels once tires have been mounted.
Old 05-28-15, 10:46 AM
Deathrow23
Deathrow23's Avatar
finally decided on 19x10.5 rear O Disk +39 instead of A disk +32.
Old 05-28-15, 02:50 PM
KamiSpeed
Former Sponsor
KamiSpeed's Avatar
All places with special ordered wheels including our shop will not return wheels even after the order has been placed to Japan.
So need to make sure the sizings are what you want before you order. And yeah O-Disk will clear the rear no problem. So I would go with that.
Old 05-28-15, 04:39 PM
Deathrow23
Deathrow23's Avatar
Can't make up my mind. Lol....for rears. Anyone help. 10 +33 or 10.5 +39 or 10.5 +26 ? Now I'm thinking +39 might be not flush.
Old 05-28-15, 08:44 PM
VTsuckah
VTsuckah's Avatar
https://www.clublexus.com/forums/whe...te-silver.html
Take a look at this thread, it should give you an idea. The silver 2is has 9”+35 and 10.5” +45. He only had the rear fenders rolled a bit.
Old 05-29-15, 08:14 AM
Goods04
Goods04's Avatar
I'm running 19x9 +36 and 19x10.5 +42. Lowered on coils w/ out fenders rolled. Sits very close to flush..
Attached Thumbnails Need help with offsets for wheels-img_0401.jpg   Need help with offsets for wheels-img_1049.jpg
Old 05-29-15, 01:11 PM
Deathrow23
Deathrow23's Avatar
Thanks for the pics. i decided to finally go with 10.5 +26 in the rear. if your +42 is almost flush, then another 16mm should hopefully do the trick. What tire size are you running? 255/35?
Old 06-01-15, 08:54 AM
Goods04
Goods04's Avatar
I think +43-45 would be flush...so +26 might be farther away from being flush, but I'm not positive. That's right 255/35..pretty mild stretch
Old 06-01-15, 12:24 PM
Deathrow23
Deathrow23's Avatar
Thanks, since your fenders are not rolled and mine is, i think that should clear at least 12mm. i do not mind a little camber since i already have camber links. i just didnt want to get something higher and not be where i wanted it to be. also, getting +26 gives the rear a bigger lip size.
Old 06-01-15, 01:50 PM
Goods04
Goods04's Avatar
Gotcha! Make sure to post some pics when the wheels/tires come in, curious to check it out! I'm sure it will look sick!
Old 06-01-15, 05:58 PM
Deathrow23
Deathrow23's Avatar
Waiting game sucks. 8-14 weeks
d0ok13
01-05-16 06:30 AM
JH48
09-21-12 11:52 AM
ohiois350
05-01-12 08:09 PM
luis300
IS - 1st Gen (2001-2005)
17
02-10-12 10:27 PM
jgonx213
12-05-11 03:26 PM
Quick Reply: Need help with offsets for wheels
