Poppin/static noise from speakers with car off
Old 05-09-15, 12:47 PM
JDMToyotas
JDMToyotas's Avatar
Default Poppin/static noise from speakers with car off
So came into my car this morning sat in the car and the speakers are make a popping noise... You kno that noise you get while connecting a AUX device. Thought it was the cable so I unplugged it. Sound went away while I was driving and using the AUX. When I tunred the car back off the sound started happening again so when the car is locked and parked it's makes this sound...disconnect and Reconnect the battery ?
Old 05-09-15, 01:13 PM
Gville350
Gville350's Avatar
Completely stock audio system or ANY aftermarket components?
Old 05-09-15, 01:15 PM
JDMToyotas
JDMToyotas's Avatar
None.
Completely stock. It's really loud too. There's nothing plugged into the AUX jack either. It only does it when the car is off.
It's the same sound as when your connecting your AUX cable.
Old 05-09-15, 01:18 PM
Gville350
Gville350's Avatar
Fully disconnect all of the factory amp connections and see if that helps at all. Check that the factory grounds are nice a tight.
Zs05039558
01-02-12 04:00 AM
Emilaman
RX - 1st Gen (1999-2003)
01-21-11 03:40 PM
encore888
04-10-05 12:21 PM
chuckisc
10-04-03 01:35 AM
fasthuh
03-09-03 08:33 AM
Quick Reply: Poppin/static noise from speakers with car off
