Any Lexus engineers here? (cutting & welding gear selector to shorten it)
Old 04-20-15, 08:38 AM
Fojo
Fojo's Avatar
Default Any Lexus engineers here? (cutting & welding gear selector to shorten it)
So, i have an idea and i need to know if it is easily attainable. I have a 06 6MT, i wanted to slice off ¾ to 1inch off of the gear shift tube and re-weld it to make it shorter. The problem is, I have no idea how the reverse tab mechanism works on the inside of the tube, is it a cable, or a rod? is it possible to shorten both and still maintain function?
Old 04-20-15, 09:34 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Why do you want to do this? To make it a short shifter?
Old 04-20-15, 07:28 PM
Fojo
Fojo's Avatar
Yea basically. it was a fleeting thought and i was wondering if it was possible.
Old 04-20-15, 08:03 PM
derboeseko
derboeseko's Avatar
They sell aftermarket short shift kits don't they?
Old 04-21-15, 03:37 PM
hirsch2is
hirsch2is's Avatar
A shorter shift shaft won't change much. Most short shifters are changed in other areas other than the shaft length to achieve a shorter shifter. I learned from experience in my e36 BMW. A common thing to do was swap a shifter from a z3 into a 3 series to make a shorter shifter. Well all it really did was shorten the shaft. The throw was so minimally changed I barely notice
Old 04-21-15, 06:14 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
Look at these threads:
https://www.clublexus.com/forums/is-...-shifters.html
https://www.clublexus.com/forums/is-...t-shifter.html
https://www.clublexus.com/forums/is-...-feedback.html
https://www.clublexus.com/forums/is-...the-money.html
Lou
Old 04-23-15, 06:33 AM
meine96ws6
meine96ws6's Avatar
Changing the hieght of the shaft wont effect the "throw."
Your pivot point and length to the linkages are still EXACTLY the same. (Below center console)
Now you will notice a change due to the leverage lost by having a shorter shaft. Hope that makes sense.
Old 04-23-15, 09:55 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Just get the F-Sport quick shifter. Done.
Superfast1
04-12-19 06:58 AM
micsil2008
RX - 1st Gen (1999-2003)
03-28-17 08:24 AM
Ltaboso
IS F (2008-2014)
12
05-26-15 09:44 PM
shiny250
02-25-10 12:08 AM
Frydryce
01-04-06 09:11 PM
Quick Reply: Any Lexus engineers here? (cutting & welding gear selector to shorten it)
