2011-2013 is350 pros and cons
Old 04-16-15, 07:52 PM
ExpressLex
ExpressLex's Avatar
Default 2011-2013 is350 pros and cons
in the market right now, any info or suggestions, anything that i should look for when buying, etc.
Old 04-17-15, 10:37 AM
deestyle28
deestyle28's Avatar
Private dealer or CPO? If CPO you should be fine for the first year. I recommend getting an extended warranty to be safe.
I had to get the following things fixed 2-3 years after purchasing. Thank goodness I had the extended warranty. I have an 07 purchased in 2010. You probably won't experience below as they probably fixed it in newer models.
Nav screen failed est cost $6000. Replaced by warranty
ball bearing issue est cost $600. Fixed by warranty.
Dead fuse for arm rest aux port I think this was an easy cheap fix.
Cracked/brittle drip moldings I complained to corporate and got replacements for free. Parts about $150
Dead LED light on speedometer needles. Warranty replaced my whole cluster.
Melting dash: not sure if this affects newer models.
Water pump had to be replaced. Heard a flushing sound behind the dash.
Hope this helps. Like I said above, you might not have/get these issues since you're looking at '11-'13. Good luck and enjoy if you decide to purchase! I still love my car even after all of that lol.
Old 04-17-15, 02:53 PM
iRock
iRock's Avatar
Go for a 12 so that you have some warranty left to get anything that needs to be fixed taken care of.
Chedeng88
03-01-18 04:14 PM
Rezno
09-14-17 10:51 AM
stlgrym3
02-21-15 08:09 AM
149MAX
04-25-14 11:07 PM
lmschuur
01-16-13 10:58 PM
Quick Reply: 2011-2013 is350 pros and cons
