Xxr 550 help!!
Old 02-21-15, 05:56 PM
is25019
is25019's Avatar
Exclamation Xxr 550 help!!
Hey, searched the forum but cant find anything im a *** when it comes to rims and tires so need some help, i have a 2011 lexus is250 RWD with the set up FRONT: 17*8, +45mm with 225/45/17, and REAR:17*8, +45mm with 245/45/17, I liek the new XXR 550s, looks like the enkei rp50rr's IMO, my question is if i can fit the same TIRES on these XXRs if i get them, woudl i need any work on fendors or anything?
specs for XXR 550s:
17x8.25 Flat Black
5-100/5-114.3 [+36mm]
centerbore: 73.1
weight:21.3
any help would be appreciated
Old 02-21-15, 06:32 PM
minato
minato's Avatar
you'll need hubcentric rings and aftermarket lugs
are you lowered ?
any reason why you going with 17?
the same tyres will fit
Old 02-21-15, 06:38 PM
is25019
is25019's Avatar
lowered on H&R springs, main reason was so i can use same tires (tryna save as much being a broke uni student), but now looking at it i think 18" or 19" will make it look like less wheel gap right?
Old 02-21-15, 06:47 PM
minato
minato's Avatar
tyre sizes really help when trying to fill the wheel gap
but yeah 18's or 19s , 17s look way too small ..
you can also look at this thread if you haven't to get an idea of what your car would look like
https://www.clublexus.com/forums/is-...tart-here.html
Old 02-21-15, 08:32 PM
SGMISF
SGMISF's Avatar
I would just keep the car stock until you can afford a set up you actually like rather than compromising because you want to reuse oe tires.
But to address your question, the tires should fit.
1blackdog
Suspension and Brakes
07-15-18 06:36 PM
TomTooFast
SC- 1st Gen (1992-2000)
10-09-11 02:17 AM
ReploidX
Wheels, Tires & Brakes Forum
01-07-11 08:16 PM
GS300ToM
01-28-09 03:28 PM
DallasGuy
07-16-08 02:45 PM
Quick Reply: Xxr 550 help!!
