Replaced HID bulbs... weird streaks! Help!
Old 07-05-14, 03:47 PM
kenjwan
kenjwan's Avatar
Default Replaced HID bulbs... weird streaks! Help!
Hello everyone.
I followed the tutorial for replacing the HID bulbs in my IS350 ('06) and it was quite straight forward. Only problem is now I'm seeing streaks of light emanating from my headlights, rather than the smooth and even dispersion I used to see. The bulbs are from Xenon Depot so shouldn't be the problem. I think it's the installation. Here's an online photo (from a different car) that kinda shows what I"m seeing, although the streaks I see are more uneven. (It's the scatter beams near the front of the car)
Can anyone help with suggestions on how to correct this? Is it simply a matter of playing with the alignment so it is centred properly?
Any tips and tricks would help immensely!
Thanks.
Old 07-05-14, 07:21 PM
kennyD
kennyD's Avatar
1. Car looks like an E-Class Mercedes? And not a LEXUS.
2. If said car, in in fact, an E-Class, it is a reflector bowl, correct?
3. I would not be surprised if it was not a correct bulb to bowl combination.
Check bulb seating, try a different set of bulbs if possible.
Check other Mercedes forums to see they're having the same issue and how to correct.
Old 07-05-14, 07:45 PM
Sffd103
Fire Slayer
Sffd103's Avatar
The op stated that its an online photo of a different car, not his 06' 2IS.
Old 07-06-14, 01:56 AM
kenjwan
kenjwan's Avatar
Yes, as stated, I am using this image to show what I'm seeing with my IS350 as the streaks appear very similar.
Old 07-06-14, 02:22 AM
ICU2
ICU2's Avatar
Are your lights HID equipped from factory?
Old 07-06-14, 05:31 AM
kennyD
kennyD's Avatar
Oh. Missed that part. My mistake.
Same is said, are your bulbs seated correctly?
Are they factory HIDs or was it converted?
Check with another bulb to see, perhaps it is a defective bulb?
Old 07-06-14, 11:58 AM
kenjwan
kenjwan's Avatar
Yes, they are factory HIDs and both sides show the pattern, although not exactly the same. The bulbs are from Xenon Depot and I haven't seen anyone reporting this with their bulbs. I'm thinking it's an alignment issue and was hoping someone here has tips on making sure it's seated exactly as it should be or perhaps, there's some sort of adjustment that can be made.
Old 07-07-14, 11:23 PM
kenjwan
kenjwan's Avatar
Here are some photos from my headlights:
On the ground:
On the wall:
Old 07-08-14, 09:21 AM
valeoray
valeoray's Avatar
Take one bulb out and compare it with the original bulb to see if the distance from the base to where the electric arc is the same.
Old 07-08-14, 11:46 AM
kumquatism
kumquatism's Avatar
That's definitely not how the beam pattern should look.
There should be a small indentation in the bulb. It'll fit in the little bump in the projector, so the bulb only fits one way. You should double check to make sure it's seated properly in the projector.
Here's a picture of the indentation I'm talking about. Notice it on the left side of the bulb base.
Old 07-08-14, 12:53 PM
pmanliu
pmanliu's Avatar
are you sure the bulb is inserted all the way? if you put the oem bulb back in, is everything normal?
Old 07-08-14, 01:23 PM
kenjwan
kenjwan's Avatar
I will try to re-seat the bulb and get back to you. Thanks for the suggestions.
Old 07-12-14, 12:06 AM
kenjwan
kenjwan's Avatar
Okay, so my brother and I re-seated the bulbs and everything looks good. While we worked on it, we realized we didn't quite correctly follow the instructions posted here. Our original mistake was to put the bulb into the socket and then attempt to fit it into the projector unit rather than clip the bulb into the projector and then connect the socket.
So much better now that the dispersion is corrected!
Thanks for everyone's feedback.
Old 07-12-14, 03:38 AM
ISland350
ISland350's Avatar
^^Thats what I love about CL, thru mistakes we can all learn something. Glad you got it sorted out
Old 07-12-14, 11:57 AM
rawr2is250
rawr2is250's Avatar
Always a great community here on CL.
mate01
09-04-16 09:14 PM
lexus71
ES - 5th Gen (2007-2012)
09-17-14 12:43 PM
w1ck3d64
09-23-09 02:45 PM
RNelson
07-21-06 06:12 PM
garbage85
Lighting
02-10-06 05:59 AM
Quick Reply: Replaced HID bulbs... weird streaks! Help!
