IS 250 Navigation Help!
I finally went through with it and bought a 2006 IS250 with rear facing camera. Though it is missing the navigation system.
I will be posting all the picture I have of the the wire harness, would be great if someone could inform me if a 2010 is250 navi system would fit mine.
note: to my knowledge the vehicle is bone stock except for what seems to have been a subwoofer upgrade.
Ash tray below and the vents above I have including trim pieces.
More pictures are posted below
I've got a JDM 05 IS350 and nav is Japanese model so did a lot of investigating re changing nav unit. There are just to many differences with the newer nav units e,g. different bus connnections and multimedia ECU. It's not just a simple change of connectors. You need to get the 06-08 nav unit or a flyaudio (which will also require wiring mods).
I ended up putting a RoadRover unit in (there's a thread on here on wiring mods reqd). The plugs I think you are referring to are the antenna plugs
kyle3481
07-01-03 02:29 PM
