clear front bumper when turning with camber
im looking to go lower in the front but i cant because my tires hit the bumper on turns when i go lower. is it possible to have the rim lip sitting just under the fender and still be able to turn without ripping off the front bumper?
I already have tab relocated, rolled fenders and i do have adjustable camber arms. i want to add 10 to 15mm spacers in front so i can get it to sit flush and not look sunken in if i have to adjust camber. Other than running narrower tires what are my options?
currently sitting here
Fire Slayer
You have done most of the options up front if you've maxed out in negative camber. What size tires are you running up front? I was one of the lowest static cars on 20's and I tucked the tire a bit but wasn't completely flush. I think you'll run into more problems running a spacer up front also. Good luck with whatever you decide.
It sounds like you're afraid of rubbing on the bumper, but beware, your fender may be the bigger problem when turning and your newfound height. The bumper is at least relatively soft and flexible. Once you hit the fender you may end up doing damage.
I've been playing around with these ideas as well. My next step is to see how much more positive caster I can run to get more lift on the corners when turning. Anyone with thoughts on this strategy? Im also on 19s though. I moved down from 20s for this exact reason. You just cant go as low.
ultran00b8
04-10-15 07:22 PM
dfwjohnd
Suspension and Brakes
08-10-14 09:47 PM
llcjr
SC- 1st Gen (1992-2000)
11-13-10 01:44 PM
