Is this a bad paint job or what?
Old 09-23-13, 08:56 AM
my1s250
my1s250's Avatar
Default Is this a bad paint job or what?
Just got my car back from Sewell Lexus bodyshop the color was fine when I first pick it up because it was cloudy that day but when the sun hits it holy moly can you see the green or whatever color doesn't look professional at all looks like someone rattle can it. When they done they left polish mark all over the car also which **** me off and couple of scratch on the inside door panel on the black part.
Old 09-23-13, 10:05 AM
Downtuned
Downtuned's Avatar
did you make sure they were using the factory paint? This looks extremely off. Either your paint before is extremely faded (which i doubt, but possible), or they used the wrong paint.
Old 09-23-13, 10:09 AM
my1s250
my1s250's Avatar
Nope paint is same color all around 8ou. It look right in the shade but when the sun is shining on it you can see the defect.
Old 09-23-13, 10:20 AM
PumaFiveOh
PumaFiveOh's Avatar
It's not necessarily a defect, it's just that metallic flake paint is extremely hard to match...which is why resprays almost never match exactly. If you go to a professional paint shop, they always mix and shoot one single batch of metallic paint, because if you need to make more, it'll never come out looking identical to the first batch you sprayed (Even though it's the same exact color code).
The second problem is that when doing these types of resprays, the "correct" and more expensive way to shoot is to feather in the surrounding panels. If you just respray a fender or door and not feather in the surrounding panels, the human eye easily catches the color difference because it's broken up by a nice black line, which in this case is the door/fender gap. And yes, I would ask them to shoot this again and try to match the paint better.....AND feather in the surrounding panels. Good luck!
Old 09-23-13, 12:16 PM
Gville350
Gville350's Avatar
Is that even a factory color? I'm having trouble thinking of a factory color that would match that color with the pearl...but I'm at a loss here.
Old 09-23-13, 12:33 PM
Noeh
Noeh's Avatar
That's an unacceptable paint job.
Old 09-23-13, 12:43 PM
Jump2man3
Jump2man3's Avatar
Yea doesnt look good at all!
Old 09-23-13, 02:06 PM
united9198
united9198's Avatar
Default Bad Paint Job
The problem is that whoever did the paint job tried to butt match the two panels instead of blending them. With some of the modern metallics, the only way to get a color match is to blend them. No way would I accept that paint job. If you are dealing with an insurance claim, don't sign off on it. If the painter is who you are dealing with, he is doing unacceptable work. This is a common issue with painters who don't follow good procedure and blend panels.
Old 09-23-13, 03:08 PM
VIPIs350
VIPIs350's Avatar
If I was you I would be on the way back to that dealership.
Old 09-23-13, 03:17 PM
reyoasian
reyoasian's Avatar
depends what year your car is
if it's really old, your whole car could've looked just like the newly painted part when it was new
however over the years under the sun, metallic paint does fade and the colour slightly alters to a degree
not to mention you won't get 100% match on metallic paint as well
Old 09-23-13, 04:07 PM
my1s250
my1s250's Avatar
It's the angle u took the picture at but when you look at it straight on the color on bottom looks blotchy. And yes it's a 2007 but I baby my car so the paint in mint condition the paint color is 8U0 black sapphire pearl. And yes I do think it is the pearl because at one angle the paint does look like it match and at another angle the you can see its all blotchy.
Old 09-23-13, 04:31 PM
Sffd103
Fire Slayer
Sffd103's Avatar
looks bad....go back ASAP
Old 09-23-13, 04:55 PM
ColtM4A3
ColtM4A3's Avatar
Blotchy and bad match. Yeah they need to fix it.
Old 09-23-13, 05:12 PM
blindlogic
blindlogic's Avatar
definitely go back and get it redone!
Old 09-24-13, 08:35 AM
hybr1d
hybr1d's Avatar
thats pretty bad, reminds me of seawater
Quick Reply: Is this a bad paint job or what?
