Strange "Check VSC" message during start.
Old 10-03-12, 03:23 PM
ChumpusRex
ChumpusRex's Avatar
Default Strange "Check VSC" message during start.
I know this is a subject that has been done, but this seems to be a slightly different variant.
Sometimes, when I start my 2006 IS250, the message "Check VSC" appears on the display *while* the engine is starting. As soon as the engine starts, the message and red triangle disappear.
The car runs perfectly; the yellow slip indicator light comes on and off as expected during power-on and starting; similarly, the yellow CEL light comes on and off as expected during power-on and starting.
I've used an OBD-II system (Techstream) several times, including on the times when the message appeared, and there are *no* error codes related to the engine, chassis, VSC, etc. The only error codes the techstream finds are historical, irrelevant codes (e.g. Air conditioning solar sensor out of range - which is a *normal* code if the car is not in direct sunlight).
Similarly, OBD-II live data shows sensible and believable data from all engine sensors, and as far as I understand the VSC system, all the live data looks legit there.
I've taken the car to an empty lot, and I've "road-tested" the ABS and TRC which work as expected. (No, I'm not going to try and test the VSC).
Any ideas? Is this even a real "error"?I'm beginning to wonder whether the message on the display is erroneous.
I suppose I could take the car to lexus, but I really don't know what they can do, as there are no error codes.
I've checked other stuff like fuel cap (although as a Euro model, I don't think it has a fuel cap sensor, so this shouldn't cause any errors) and can find nothing wrong.
Old 10-04-12, 12:06 PM
Gville350
Gville350's Avatar
Slight delay between the TPMS and the antenna during start-up perhaps? Vehicle thinks either no or low-pressure until the systems catch up to themselves? Just a thought.
Old 10-04-12, 03:56 PM
ChumpusRex
ChumpusRex's Avatar
I think you're probably sort-of right, and that it's some system that is taking a bit longer to boot-up than normal, so the warning is appearing. But once booted up, the light goes out as there is no error.
It's not the TPMS though, as my car isn't fitted with the TPMS option.
Old 10-02-13, 05:39 AM
GRiDy
GRiDy's Avatar
Default "Check VSC system" only on startup goes off after.
Hi Guys,
were you able to solve the problem?
I have a 2007 toyota camry 3.5 v6 2grfe a/t
with multi-info display and smart key with vsc.
Is this normal? having same issues as your lexus.
At initial startup "check vsc system" flashes(multi-info display) with red triangle "!" and dings once when I do this start procedure:
1. scroll through(push button switch to the "switch On mode" and wait for the abs,trac and airbag lights to go off..
2. then depress brake pedal,
3.then press the push start again for ENGINE START.
It NEVER flashes anything(warning or dings) when you directly step on the brake pedal then startup the engine..or pop up any warnings or lights when driving around.
Had it scanned and no error codes were found.
but upon reset, it did'nt flash anymore when doing the first procedure,
But it came back after a couple of days of driving.(flashes ONLY once again ON STARTUP and then no more)
also did the zero point calibration reset without any improvements.
Thanks in advance.
-GRiDY
Old 10-02-13, 04:53 PM
qqqqball
qqqqball's Avatar
disconnect the battery...step on the brake...reconnect the battery and it should reset the ECU. Or go down to AutoZone and buy an OBDII reader so you can check it whenever it throws the code...
Old 10-02-13, 06:45 PM
ISMELLRICE
ISMELLRICE's Avatar
I had that issue wmright before my battery died...i replaced the battery and all was back to normal
Old 10-07-13, 06:13 AM
GRiDy
GRiDy's Avatar
Tnx for the reply guys... Will do the ecu reset tom, if it doesnt work will get a new battery just to cancel it out as the cause. Will post back results asap.
Old 10-07-13, 11:08 PM
amoua12
amoua12's Avatar
Just had this problem. I just disconnected the battery and it went away.
Old 10-08-13, 12:51 AM
LexoticJ
LexoticJ's Avatar
This happened to me a couple times and it seems to be the electrical harness that's plugged on the intake manifold
Jbakyy
12-13-22 10:35 PM
DAbernathy
GX - 1st Gen (2004-2009)
07-14-19 04:13 PM
teero360
07-18-17 06:36 AM
LexHelp
09-16-14 07:23 AM
Lunchbox
Maintenance
08-01-07 09:37 PM
Quick Reply: Strange "Check VSC" message during start.
