F-Sport 2011 Bumper upgrade from Sewell
#61
i had the same question. i went ahead and tried to duplicate a shopping cart to match the 2011 fspor tconversion list,it did come out cheaper shipped.but i left out the fog light bulbs and the weather strip. i was going to try my old weather strip first cuz it might work not sure if anyone reused the old one yet, but ima try it.same with the retainers and fasteners and clips,jus take your old ones off carefuly and you should be able to reuse them,i think if you order the parts separate each individual part should come with everything you need to mount (clips,fasteners,retainers) plus if you have a 06 most of the retainers and fasteners wont even line up with the fender liner anyways...everything else in the kit is necessary...but then again i could be wrong about everything lol ill let you know how mine comes out in about 3 weeks cuz im doin it that way, wit the money i saved on the not needed stuff im using to buy a bumper absorber andair ducts.
#62
It seems the price has gone up.
http://is.sewellparts.com/accessorie...2006/4539.html
Online: $1813.39 with out the bumper being painted.
Do clublexus member get discount?
#63
#65
I'm gathering the parts to do this mod in a few months time including the LED headlamp mod.
Do the headlamp brackets have to be changed because the old ones dont work with the new bumper? or are they being changed to accommodate the LED headlamp? I know that some people who just do the LED headlamp upgrade cut out their old bracket. But I am assuming cutting the bracket works for headlamp upgrade and not bumper upgrade. Is this correct?
Does anyone have the Part Numbers for the two headlamp brackets?
#69
Hi,
I was involved in an accident with a SUV that had a tire blow out which ended up damaging my front end includes bumper, grill, fender and right headlight. My car is a 2007 with 2012 led headlights. I'm looking to take the opportunity upgrade my front end to 2011 f sport bumper. My auto shop said no problem but I need to provide him with all the part numbers required for the bumper upgrade. I already modified the headlight bracket so that is not needed.
From the lists of part number I can gather, can someone please confirm this is all I need? Can anyone provide the foam absorber for 2011 as well? Thanks for your help in advance.
52119-53990 Front cover*
53113-53030*Bumper Lwr Grill*
52125-53030*Rh*Fog lamp Brkt*
52126-53030*Lh*Fog lamp Brkt*
81481-53020*Cover, Fog Lamp, (Right/ Passenger Side)
81482-53020*Cover, Fog Lamp, (Left/ Driver Side)
53112-53220*Radiator*Grill*
53111-53250*Radiator Molding*
53119-53050*Grill Protector*
52115-53070*Rh Bumper Support*
52116-53070*Lh Bumper*Support*
81210-0w050 Rh*Fog lamp*
81220-0w040 Lh*Fog lamp*
52129-53909*Tow Hook Cover*
75392-50080*x 2 Clips Retainer, Outside Mo
90467-07201*x 2 Clips
75392-50070*x 8 Clips Retainer, Outside Mo
76851-53020-B0 Rh Side Spoiler (or*7685153020A1)
76852-53020-B0 Lh Side Spoiler (or*7685253020A1)
90467-07146*x 2 Clips*
52535-50060*x 2 Clips
52536-53011*Lh Bumper*side retainer
52535-53011*RH Bumper side retainer
52119-53990*COVER, FRONT Bumper
93567-A5014 Screw, Tapping
93567-A5012 Screw, Tapping
90159-60603*Screw, w/ washer Tapp
82824-60460*x 2 Fog Lamp Connector harness – Connector Assembly
InThaMakin
08-02-17 03:53 PM
