Anyone ever have the mounting bracket cracked on their headlights?
Old 05-09-12, 09:51 AM
Lexus408
Lexus408's Avatar
Default Anyone ever have the mounting bracket cracked on their headlights?
Took my car in for the 10,000 mile service and come to find out my mounting bracket was cracked and that's why my right headlight does not fit in place. Shouldn't this be covered under warranty? Anyone know how much this part cost?
Old 05-09-12, 09:55 AM
ohiois350
ohiois350's Avatar
if your headlight doesn't look proper installed it should cover under warranty, but I wonder what bracket are you talking about?
Old 05-17-12, 10:17 AM
Gville350
Gville350's Avatar
Yep, mine broke though when I ran over a thick tree limb in the road. I believe the bracket or tab he is mentioning is an upper tab that connects to the fender area. My passenger side headlamp sticks out about a couple more MM than it should now...but only I really notice it. It is part of the entire headlamp housing...I don't believe it is a component that can be replaced unless you replace the entire headlamp.
To fix the break though, you can simply try your hand at plastic welding or use epoxy.
Old 05-17-12, 10:45 AM
kams229
kams229's Avatar
It can b replaced look at the headlight assembly chart on Ltuned parts it will show the replacement tabs
Old 05-17-12, 11:13 AM
B16da9
B16da9's Avatar
This man is correct, the replacement tab is about $24.00 from the dealer. I would also add some expoxy on it to make it stronger as it's screwed on.
Old 05-17-12, 03:49 PM
kams229
kams229's Avatar
That isn't a bad idea I have come to find out that those tabs r extremely frail
Old 05-17-12, 04:09 PM
Gr33nHrn3t
Gr33nHrn3t's Avatar
This has happened to me too so I ordered the mounting tabs from my local lexus dealer and had one of my techs replace it. It also came with screws...
Is it the lower or upper mounting tab?
81196C 8119653020 RETAINER, LH HEADLAMP PROTECTOR, LWR LH $10.09
81194D 8119453010 RETAINER, LH HEADLAMP PROTECTOR, UPR LH $30.81
81195B 8119553010 RETAINER, RH HEADLAMP PROTECTOR, LWR RH $10.09
81193D 8119353020 RETAINER, RH HEADLAMP PROTECTOR, UPR LH $30.81
Old 05-17-12, 07:06 PM
kams229
kams229's Avatar
ItIt's a little cheaper through L tuned
Old 05-19-12, 09:41 AM
Gville350
Gville350's Avatar
Oh, so when Lexus redesigned the headlamp housings they made the mounting tabs replaceable. Lucky dog! My '06 headlamp mounting tabs are integrated into the housing. I'll have to epoxy mine.
Old 05-19-12, 09:43 AM
MattieVSS
MattieVSS's Avatar
Its a common rookie mistake. A young technician with no patience or finesse. Happens more time than ya think.
Old 05-19-12, 10:54 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
They're all integrated into the housing. When you use the repair brackets/tabs, you cut the old ones that are moulded into it off and screw the new ones in.
The repair parts are for all 06-12 models.
Jeff
Old 05-19-12, 11:30 AM
06isDriver
06isDriver's Avatar
well thats good to know, I've had to jb weld mine back together. It's still holding strong though
Old 05-20-12, 08:07 AM
Gville350
Gville350's Avatar
Hmmm...so P/N 81193D (RH) would fix this broken tab?
Old 05-20-12, 08:46 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Yup.
Jeff
Old 05-20-12, 06:34 PM
Gville350
Gville350's Avatar
Will hotdog! Thx Jeff!
Quick Reply: Anyone ever have the mounting bracket cracked on their headlights?
