Can't switch to AUX input??
Old 05-07-12, 10:16 AM
vital
vital's Avatar
Default Can't switch to AUX input??
For some reason my AUX input is bypassed all of a sudden. I have the stock audio (non-nav) on my IS250 '08. It's always been working fine but now I can't even switch to it. Pressing the DISC/AUX button switches it to CD/MP3 so I know the button is not broken. Cycling through the MODE button on the steering wheel changes it to everything except AUX. What could it be? Dead fuse for AUX?
Old 05-07-12, 10:32 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
did you plug anything in the port?
Old 05-07-12, 10:40 AM
vital
vital's Avatar
Yes, tried both plugged in and unplugged. Before I would be able to switch to AUX even without anything plugged in.
Old 05-07-12, 01:07 PM
CANDYAPPLE
CANDYAPPLE's Avatar
i have the is250 and it wont go to aux unless i have something physically plugged into it. change the plug it might be damaged and try to use it again, if not the aux box might be messed up. i would just check to see if the connection is still good and the wire before trying something else. oh and also make sure the unit you are using is working proplerly or plug something different into it and see if it works
Old 05-07-12, 07:09 PM
KillaIS250
KillaIS250's Avatar
Likely a damaged cable. Replace it with another and see if your problem goes away.
Old 05-08-12, 05:18 AM
Bichon
Super Moderator
Bichon's Avatar
As CANDYAPPLE says, that's not right. You should NOT be able to switch to AUX with nothing plugged in.
I believe there is a part of the jack that detects whether a plug is inserted. [I've observed that I can switch to AUX whenever a plug is inserted into the jack, even if there is nothing connected to the other end of the cable -- but if I remove the plug I can't switch to AUX] If replacing your cable with another one (make sure it has a 3.5mm plug, not 2.5mm) doesn't help, I'd suspect the metal finger in the jack that detects whether a plug is inserted may be broken.
GAP55
ES - 6th Gen (2013-2018)
11-16-18 02:17 PM
revhappy
12-21-13 11:25 AM
Kumar350
11-30-13 09:23 AM
Beerguy
GS - 1st Gen (1993-1997)
08-29-13 11:02 AM
ravz
04-15-08 07:07 AM
Quick Reply: Can't switch to AUX input??
