Any 2IS running 18x10 +25 all around? Cant seem to find any pictures?
Hey Guys, Im looking to run some 18X10's all around on a IS350. +25 Offset.
I was wondering if I could or would clear?
going for the Stretched and Slammed look.
I've been search a Bunch and I cant seem to find any with that type of specs..
No looking to Pull and Repaint Fender Wells... Just looking to roll with a Roller...
Please Post up pictures if you can...
Any help will be great!
I was doing research on 18s as well and from what I got, from 4 different sources, is that 10s in the front are a bit too wide. The widest to go is 9.5 even stretched is pushing it. You can get away with a 10 in the back running like a 255 tire but in front on a 225 or 235 and 10 is a bit wide. At the end you would have to pull the fenders a bit unless you are leaving it stock height. But on stock height, you wont get the stretched and slammed look right and no point to stretch with huge fender gap. I ended up going with 18x8.5 and 18x10 both at +22.
and if your fender rolling guy is not competent enough, you may need to paint as well.
Thanks guys... Yeah I wouldn't want to pull and roll that much In order to fit 18x10s in the front... I just want a super big lip like the xxr 521 18x10 25+ setup since they're cheap... Just something to play around with until have have ballet money. Lol
Guess since xxr only make 18x10 and 18x8.5 option I'll have to go with that...
