Vinyl roof: How to work AROUND the shark fin??
Old 09-01-11, 03:54 PM
ThermonMer
ThermonMer's Avatar
Default Vinyl roof: How to work AROUND the shark fin??
For those that have vinyled the roof themselves, or watched an installer vinyl their roof:
How did you/him negotiate around the shark fin antenna?
It seems that i should either:
A. Pre-cut a sliver for the shark fin and use the fin as a starting point to lay down the material. Peel back the adhesive in an outwards motion starting at the fin. (I feel that this could lead to so uneven stretching in the material over the course of the roof)
OR
B. Pretend there is no shark fin. Start laying down the material at the rear and work my way towards the front of the car. Figure out how to work around the shark fin when i get there. This could be haphazard...
Also, is it better to leave the sunroof open during all of this, as to avoid the bulges of the moonroof perimeter seal?
Thanks.
Old 09-01-11, 05:11 PM
ISThree
ISThree's Avatar
remove the shark fin first then apply the vinyl?
Old 09-01-11, 06:40 PM
ThermonMer
ThermonMer's Avatar
ok, how do i go about removing the headliner to get to the antenna? n/m got it. apparently you yank off the dome light and reach backwards.
Old 09-01-11, 06:47 PM
jbounnoi
jbounnoi's Avatar
^ you reach backwards take off the giant bolt, and theres squeeze on both sides and it'll help if theres a second person to pull from the outside
Old 09-01-11, 09:26 PM
shiny250
shiny250's Avatar
yeah keep the moonroof open as well. goodluck!
Old 09-01-11, 10:15 PM
ShadowISF
ShadowISF's Avatar
^^^I thought you will have to remove the headliner before removing the sharkfin antenna. I didn't know you can just yank the light off...but that's good to know!
Anyway,when I got my roof wrapped, they measured the base of the sharkfin antenna and pre-cut the vinyl to the base of the sharkfin before they put the wrap on.
Old 09-01-11, 10:19 PM
IS3003o3
IS3003o3's Avatar
no need to remove the headliner. i did this couple weeks ago with my 1st attempt at wrapping the roof. you just have to remove the rear dome light assembly and once that's out there's an exposed bolt about 3 inches back that holds the antenna down.
Old 09-02-11, 05:19 AM
ThermonMer
ThermonMer's Avatar
check on the sharkfin.
lastly - could i vinyl over the side rails with the same main piece of vinyl?? or should i vinyl them separately?
Old 09-02-11, 07:46 AM
IS3003o3
IS3003o3's Avatar
^^ i was thinking about this too. i might just not wrap the side rails at all, but i have extra vinyl to work with just in case i do haha
Old 09-02-11, 11:24 AM
ShadowISF
ShadowISF's Avatar
I wouldn't wrap the rails at all. It OEM color on them looks good with a wrapped roof. But if you decide to wrap it, then do it seperately.
Old 09-02-11, 11:27 PM
KGeezzy
KGeezzy's Avatar
cool info! i want to wrap mine to but was scared about the head liner. thanks for the info guys and good luck with your project!
Old 09-03-11, 10:02 AM
ThermonMer
ThermonMer's Avatar
alright, well i spent $100 on film. took off the shark fin and precut the vinyl for it. took off the roof rails and precut the vinyl for that. then when it came time to do the roof, it was a disaster. do NOT attempt to do this by yourself - its not happening. you need at least two people. i did the rear corner, but the film started bunching up, since i didnt have other ppl to stretch out the vinyl. the heat gun and professional vinyl squiggie wasnt enough to compensate for the lack of hands. 95 and humid - the adhesive was basically washed away by forearm sweat. i ended up trashing the vinyl.
4 hours, and $100 down the drain. at least i could say i tried.
however, i did debage the rear, plug, and paint the holes. as well as plastidip the rear reflectors. at least im satisfied on that front.
Old 09-03-11, 10:32 AM
relaxfoo
relaxfoo's Avatar
damn that sux...how did you take the roof rails off w/o breaking them?
mrkwinning
08-24-16 07:27 AM
ZAM
RC - 1st Gen (2015-present)
13
04-30-16 10:16 AM
tmoney16
09-17-14 01:54 PM
ball4lyfe
05-11-11 10:44 AM
pchan0
02-26-11 10:35 AM
Quick Reply: Vinyl roof: How to work AROUND the shark fin??
