Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
Old 02-01-12, 04:01 PM
  #301
Lexs350
Lexs350's Avatar
Great price...looks fantastic....job well done.
Old 02-01-12, 04:06 PM
  #302
UtoyZ
UtoyZ's Avatar
Originally Posted by Fapout
How do you get the pins out and moved around in the headlight harness?
Edit: got it. You have to remove the white plastic cap to get in there to hit the clip.
more details on this pls. i need to relocate some pins
Old 02-01-12, 04:17 PM
  #303
Vroomin350
Vroomin350's Avatar
ok sick, I am gonna need your guidance in removing my old ballast if you dont mind.
Old 02-01-12, 05:56 PM
  #304
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
Originally Posted by Vroomin350
right but I heard in order to get to the ballast on the old headlights you have to break them, it seems joe z knows a different way of removing the ballast and not destroying the old headlight. Just in case I ever need to use them again.
That is what I want to know.
Tools: Mini Flat head screwdriver & small needle noise pliers
Take apart the silver connector that attaches to HID bulb.. Once carefully taken apart, the two wires become free and clear..!! Reverse steps once you have transferred the ballasts.
Time: Less than 5 minutes If you don't break anything.. But really it's self explanatory while your doing it.
It really is that easy.. Afterall, the light manufacture has to get the ballast in there some how guys..
This may have been the 3rd or 4th time that I have wrote this..
~ Joe Z
Old 02-01-12, 09:14 PM
  #305
Vroomin350
Vroomin350's Avatar
you mean the metal socket that locks over the bulb? how is it taken apart? haha
Old 02-01-12, 09:48 PM
  #306
ohiois350
ohiois350's Avatar
yeah, I got my took apart, but the wire some how is stuck in there, it tight for even just the wire to pull out, i force to pull it out, lucky i didn't break the wire I don't know if I could put it back to the old light in the feature?
Old 02-02-12, 06:05 AM
  #307
Vroomin350
Vroomin350's Avatar
IDK I am still waiting for JOE Z to elaborate a little better as to what needs to be taken apart, I am tackling this in a few days and need some help.
Old 02-02-12, 04:18 PM
  #308
Joe Z
Joe Z's Avatar
Exclamation
Really....?? I'm NOT going to write about it for a 5th time...
Sorry..
Here's a visual:
Attached Thumbnails Pics of my '06 IS250 with 2011MY headlights w/ LED Strip-lexus-hid-connector.jpg
Old 02-03-12, 10:00 AM
  #309
Vroomin350
Vroomin350's Avatar
Joe I KNOW what the piece looks like, I took off the metal "casing" thats on it which also holds the "heatwrapping" . but the wires are still inside the black plastic, I tried pulling on them and NOTHING.
Thats why I keep asking.
Old 02-03-12, 11:26 AM
  #310
Joe Z
Joe Z's Avatar
Arrow
The Black Plastic socket also comes apart... To ultimately release the two wires...
It's been years since I have done it, but it should be pretty self explanatory.
Sounds like "ohiois350" already did it... maybe he took pictures of the process.. ??
~ Joe Z
Old 02-03-12, 03:12 PM
  #311
Vroomin350
Vroomin350's Avatar
damn, can ANYONE please explain how to take apart the black piece holding the two wire???
Old 02-03-12, 03:34 PM
  #312
Joe Z
Joe Z's Avatar
Mini screwdriver ???
Post a picture or two of what your looking at.. Maybe I can assist you visually..!!
~ Joe Z
Old 02-03-12, 04:12 PM
  #313
UtoyZ
UtoyZ's Avatar
the process of taking that socket apart must be explain thoroughly for those who want to go that route. i tried taking it apart and ended up snapping the plastic and still i wasn't able to open it. just ended up cutting the wire which i didn't really wanna do.
Old 02-03-12, 04:36 PM
  #314
Joe Z
Joe Z's Avatar
Exclamation
Weird.. I took me like 2 minutes to take apart...
But that was a couple of years ago... (on my first try)
It really can't be that complicated.. There isn't much there to take apart.
~ Joe Z
Old 02-03-12, 10:05 PM
  #315
ohiois350
ohiois350's Avatar
~ Joe Z
sorry I didn't take any pics,
Vroom350 after you take the metal silver cover off and the plastic socket expose, on the plastic socket has two small clip, use very small flat screwdriver to pry that two socket plastic clip together apart, and you can pull out the wire, I would take some pics tomorrow
Quick Reply: Pics of my '06 IS250 with 2011MY headlights w/ LED Strip
