Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
#1291
Noob question...
The 2011 year model has the same engine, same GDI system, same compression ratio etc., so does this carbon build up on the valve stem also apply to the 2011 IS250s?
I have called a few dealerships and asked, one of them said flat out no, the other scheduled an appointment for me to run a diagnostics test (for free) to test if the engine is misfiring.
I am concerned because earlier this week, my car began to rev itself at a red light after a cold start and driving normally for about a mile...
Any of you 2011+ owners experience this carbon build-up problem? If so, what was your success with Lexus on taking care of this issue?
#1292
Noob question...
Bumping this thread..
#1293
Had the following below done about two years ago on my 2008 CPO IS250 as a result of a lot of lights coming on the engine shaking so bad the car shook. Unfortunately, the same issue has occurred again a mere 15,000 miles later, if that. I'm considering just trading the car and cutting my losses. I still owe two years on the car and don't care to be stuck with a bill when all of this goes even further south.
From the invoice...Vehicle failed misfire test and TSB was performed. Service/parts used...
1 Gasket kit, engine
1 Ring set, piston
3 piston sub assy
2 piston sub assy
1 piston sub assy
1 lof is250
1 replaceable element
1 gasket
And a bunch of ransoms - oil, oil pan, atwfs, non-chlor brake c, nuts, locks, etc
1 Ring set, piston
3 piston sub assy
2 piston sub assy
1 piston sub assy
1 lof is250
1 gasket
#1296
I'm looking at grabbing a 2010 myself.
#1297
Don't do it! It is a headache and you're better off buying an Lexus with the 2GR-FSE..
#1298
#1299
theres a 2010 is250 awd with 36K miles on it, for $15,000 Canadian currency. it's rebuilt status hence the low price, but it was just body damage. I'm really considering it. I'm not overly concerned about the carbon buildup issue. with only 36k miles it wont be bad yet, and I can install a catch can, and run engine cleaners in the gas to minimize any future buildup.
#1300
#1302
Oh, Did not realize, i;ll take a gander. but they would be hella expensive.
I think it was mid 2010 they changed up the rings to reduce it, but i think it still happens to an extent.
#1303
Thanks for the input will be calling the dealer and asking them with vin on hand hopefully it's still covered ! I want to take it in anyways to see how things are running since i got it at 99k !
