DIY: LS460 door locks & door cup LEDs
Old 04-16-10, 02:02 PM
  #61
eXstasy
eXstasy's Avatar
Bump for updates, if any. I appreciate all the info so far though
Old 04-16-10, 02:16 PM
  #62
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Sorry - Nothing to update for now. LoL
The wiring as shown (only 2 ways for the drivers door) is the only way to do it right now...
Unless you rewire to inside the car.
Joe Z
Old 05-16-10, 11:09 PM
  #63
AznJason
AznJason's Avatar
Dang, I ran into the same issue as Joe Z. I have an '06, no Sport/Lux package. I used the white wire with the black stripe from the larger harness and the orange wire from the smaller harness. When I turn off the car, the passenger light stays on but the driver's side turns off. I think based on my car, I followed the instructions correctly... did anyone else try this on an '06?
Old 05-17-10, 06:55 AM
  #64
iSuxeL
iSuxeL's Avatar
So these stay on like the center console LED from above?
Old 06-06-10, 04:44 PM
  #65
acefalcon2
acefalcon2's Avatar
i can't get it to work i don't know where it is wrong... i tapped b;lack to striped black... the white to the orange.... didn't use the T-Tap though used the 2 wire splicer...
Andre
Old 06-20-10, 11:44 AM
  #66
maxframes
maxframes's Avatar
So, has anyone been able to sort out the connections to make both sides act the same?? i.e. on until the door is open??
Old 06-21-10, 03:53 PM
  #67
Joe Z
Joe Z's Avatar
^^ From what I got... its not gonna happen...
Joe Z
Old 06-21-10, 04:57 PM
  #68
Sffd103
Fire Slayer
Sffd103's Avatar
I just had mine done. Love them! Subtle but nice mod! I had my buddies wire it to power as long as the car is on. Smooth!
Old 06-22-10, 09:23 AM
  #69
javyLSU
2IS OG
javyLSU's Avatar
Originally Posted by sinister2c
i did this using 3GS parts and wired it to the LEDs under the kick panels. mine dim and light up when I shift from park to drive...
I was thinking about your solution a few months ago and the more I thought about it and observed the behavior of the footwell LEDs, the more I liked that as the preferred behavior for the doorcup LEDs - so I rewired them. I tapped the footwell LEDs, and ran the wire through the fender and door, into the door panel up to the door cups. I did this on both passenger and driver sides.
Although the "mismatch" in behavior didn't really bother me (you have to lean forward to see the driver's side LED anyway), what I really liked was the dimming behavior when you shift from P to D. In P the LEDs are at 100% brightness, when you shift to any other position they dim about 50%. It's a lot more work to wire them this way but IMO well worth it - the dimming effect it provides is very classy. Thanks sinister2c!
I'll see if I can take some night shots to give all those asking an idea of what it looks like in the dark.
Javier
Old 06-23-10, 09:26 PM
  #70
IS250Slvr
IS250Slvr's Avatar
Can someone tell me where i can order the parts i am going nuts on finding them and i dont want to order the wrong stuff. Plus what does a project like this cost for parts ???
Old 06-23-10, 11:39 PM
  #71
lexy250
lexy250's Avatar
http://is.sewellparts.com/accessorie...0-2006-77.html
Only replaces the door locks and you will need to order 2 sets. The led is optional. Reading very thoroughly usually helps ><
Old 07-12-10, 06:22 AM
  #72
willi3ja
willi3ja's Avatar
bump for any night pics
also, does it seem to be more neccessary to wire them in with the dimming footwell lights, or are they not too bright just wired in the door panel?
Old 07-12-10, 09:20 AM
  #73
javyLSU
2IS OG
javyLSU's Avatar
The brightness doesn't change depending on where you wire them to - it's the behavior that changes. The brightness when I had them wired to the window switches is exactly the same as when I wired them to the footwell LEDs.
I don't have my car right now to take any night pics, but I'm not sure what the point of them is - it's not going to look any different than the picture I already posted - the light looks a bit brighter in that picture because I left the shutter open longer to exaggerate the light output so you guys could see it.
Javier
Old 07-12-10, 09:35 AM
  #74
willi3ja
willi3ja's Avatar
Thanks for the pic
I was just trying to figure out if they were too bright/stood out to much without being dimmed while driving, or if they were fine to just be on "full power" the whole time
Old 07-12-10, 09:49 AM
  #75
javyLSU
2IS OG
javyLSU's Avatar
It's worth the extra work to run them to the footwell LEDs in my opinion. The behavior is perfect.
Javier
Quick Reply: DIY: LS460 door locks & door cup LEDs
