Specs after alignment
i did an alignment yesterday at my dealership after dropping it on f-sport springs for about 3 weeks
here is my specs sheet
does everything seem to be in specification ? i dunno how to read spec sheets so i jus wanted some opinion
thanks!!
oh and it seems like i would still have to angle the steering wheel lil bit to the right wen i am driving .. but i dunno if this is due to the grippy tires and the road curvature ..or just bad alignment
thanks!!
Tech Info Resource
Looks pretty good, but the right rear camber is strange. Did they check tire pressures and set them correctly? You shouldn't have that big a difference unless your pressures are wrong or something is bent. There is no adjustment, so there's nothing the shop can do about it.
Your toe numbers look decent. I'd prefer to see less toe on the rear, but what they gave you isn't bad at all.
Tech Info Resource
If the steering isn't on center when you're driving straight down the road, I would take it back and have it fixed. I'm picky about that. There's no reason your wheel shouldn't be pointed dead ahead if the car is straight and the alignment is good.
I am coming from driving an '05 honda civic for years with the alignment off. In order to go straight down the road,t he steering wheel was not dead center, it was slightly to the right of center
I went to the honda dealership once, and once they "fixed" it, the steering wheel had to be slightly left of center in order to go straight.
I went a third time and it was back to start - it was slightly right of center again.
At that point I just gave up and dealt with it. It was annoying initially but over time it felt "normal" to me. It was normal for me to drive a car with awful alignment. I got used to it.
After that, coming to this brand new '09 350, the steering just feels like a dream. It's utter perfection.
