Please HELP...this is serious...
hello my fellows CL members... I really need help on my situation. Lately I've been having moisture in my front passenger headlight housing, unfortunately last week my low beam turned off completely. However i still have the DRL working and the PARK light. I took it to the dealer and said that the warranty is voided coz i got into an accident last year and they couldn't replace the set...My friend who work as a service tech, tried to swap my bulb to a new bulb, but there's no luck he said it might be the ECU computer (I'm assuming they mean by the BALLAST is not working) They said it will cost me $1000 to fix it, because they dont come in separate parts. I'm hoping that someone here knows where i can get a OEM ballast for the IS...Its very frustrating that i cant get the pieces that i need instead of replacing the whole product itself... thanks for the time reading this..hope to hear some solution..
iam not totally sure where u can get a stock ballast but iam not sure if this works.. but why dont u just swap out the stock ones with a new set of aftermarket HIDs for a lot cheaper...
ebay.
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
If it is in fact a ballast error.
However, the moisture in your headlights should definitely be taken care of as well.
body shop had lifetime warranty for their workmanship, but the parts is one year..i was arguing that the workmanship sux...but they said that the car is still intact and the parts is not their problem...its the dealer...i dont want to be dealing with this people, theyll get their KARMA..but thnx for suggestion...THNX TO ELLY i called the guy and i'm going to pick it up now...
Probably moisture got into your ballast and fried it. Our stock ballast (denso) is not very waterproofed at all. Just get the ballast on ebay that ELL Y posted. But you will have to take the bumper off and take the headlight off, because the OEM ballast is attached to the bottom of the headlight.
well here's the thing...sometimes the light turns ON..while i was picking the ballast earlier, i try to just turn on the light, then it did...then when i got home..i turn off the car, and then turn on the engine again the light was OFF again...wat could it be?
rxrom
03-12-19 08:07 PM
