ECU for IS
ECU for IS
I've looked, but can not find a new modded ECU chip for the Lexus IS. Has anyone heard of one or seen one and how the car performs afterwards?? thanks for the help.
thanks for the quick reply. Since there aren't any out yet, can we use another ECU chip from another Lexus model that will work in the IS? Suppose the ES becuase most of the stuff is the same, i dont know if this would work flawlessly or if it is not possible.
VAC (Velocity Advanced Computer) from HKS.
http://www.hks-power.co.jp/products/...speed/vac.html
The max speedmeter is 260KM/h. However, the fastest we can run is 225KM/h because of the limiter.
This one is designed to break the limiter.
I ever saw a report from HKS. IS350 with VAC can run to 270KM/h in 5th gear at 6000rpm.
http://carlife.carview.co.jp/UserCar...rNoteID=125735
I really hoping we see some chips soon The HP bolt-ons we have to choice from are fairly limited and debatable on power gains...
Tech Info Resource
You won't ever see "chips" for any Toyota ECM. They hard wire the memory into the ECM. Thankfully it's now flash memory, it used to be nothing but a CPU with onboard PROM, and they'd sever the PROM links after programming to ensure no one could change the code without either a piggyback or a daughterboard with ECM (a la G-Force/Technosquare).
Domestic manufacturers do have replaceable PROMs (or EEPROMs), but Toyota has never done this, and has only very recently decided to go to flash memory. The real win would be to crack the Toyco encryption for the checksum they use, and reprogram the maps for more power friendly operation without the speed limiters. FWIW, the entire Scion tC community has been trying to crack their ECM to get rid of the 127 mph top speed limiter since the car's release without success.
Clara13
04-08-16 06:59 AM
