AFS Head light
AFS Head light
My friend just got a Ford Focus ST here in Taiwan.
The car is fun to drive, lot and lot of power in the entire rev range, but the interior is a bit on the cheap side.
But his head light was awesome, it is a hallogen light with AFS system, but I can actually tell that AFS is at work, unline my IS.
here is my question how do you check if AFS is working, is there a way to find out from the look of the headlight housing to see if my car have AFS or not.
I have HID, but I don't know if I have AFS or not.
Please advise.
Please advise.
I don't know if the IS in Taiwan has the sports pkg or not but if you do, you definitely have AFS.
I have AFS and I can tell that it works when I'm turning corners. I can see the headlights following the curb as I turn. There's also a way to turn AFS on/off too. It's on the insrument control panel somewhere, I can't remember where. LOL
I have sport pkg, and I think I have AFS but I just can't see it in action like my friends car.
I will give the part in the wall trick a try, where do I turn it on and off the AFS.
my manual is in chinese and I am just too lazy to read a chinese manual.
Originally Posted by monkeyfarm
Won't work. AFS only functions above 6mph (it's in the manual). Just use your satellite switch and make sure AFS is enabled (again, instructions are in the manual). It's pretty obvious that it's working when you're driving.
I can tell the AFS is working by looking down the middle of the lights and you will see it shifting towards the side you are turning and will shift back down the middle when you straighten the steering wheel.
I see it working all the time when I go on the entrance ramps to the freeway. The RX330 loaner I'm driving.. the AFS on that is so sensitive. It turns even when I'm not turning.. and the lights seem to twitch all the time. Beam has a nice coloring to it on the cutoff too..
It's very apparent for me also. Actually it's probably too apparent as I tend to watch the lights move back and forth too much. Hopefully, the novelty will wear off.
it's most obvious when the car returns to center after a turn, as the light quickly swivels back to the center position. Just remember only one light (the one inside of the turn) turns at a time. If you want to know whether your car is equipped with AFS, cycle through the menu switch to the left of the steering wheel. Is the IS popular in Taiwan?
Originally Posted by yellowssm
I know I have it on my car cause the AFS OFF light keeps on flashing since I have lowered my car
I had an RX330 loaner when my tires were getting replaced.
The AFS seemed pretty noticable. watch the Arc in the middle of the HID pattern.
I also noticed that the beam was pretty weak, compared to the 4500k Mtecs that I have on the IS.
I also have a random brand 4300k on my 3000GT, which is also a lot brighter than the RX330s factory HIDs
