IS 350 vs G35 Coupe
#76
Originally Posted by G35_TX
Looks more like a tire PSI than anything else. The dead giveaway is the center of the tire.
I have those same tires and they wear faster on the outer parts than the inner anways. My friends Mazda 3 also looks the same. The tread on the outer parts are much less deep than the inner part. But a awesome tire. GY GSD3-F1
#77
Originally Posted by al503
Not PSI. I had them at 40 PSI cold, which is a little on the high side. If I had them at 30 then it might be because of inflation.
Interesting.
#78
Well the deal is I don't see how both the outer ends wore like that. Tire feathering is usually only one side. Even alignment issues is usually one side.
Interesting.
Interesting.
#79
I soid my 2001 lexus is300 one best cars I owned
but g35 coupe is also great car and very fast
here my new g35 coupe
I have over 325 hp right now
#81
How'd you calculate the 325 bhp? Did you dyno on the dynapack or dynojet? Also, what value did you use for driveline inefficiency?
Prowlerjm
08-15-07 03:17 PM
