Installation: 2nd gen IS Ipod Integration.
Old 02-20-06, 09:28 AM
aznevoviii
aznevoviii's Avatar
Default Installation: 2nd gen IS Ipod Integration.
IPOD Solution on 2nd Gen IS:
Things that you need - a)90° car charger adaptor.
http://www.radioshack.com/product/in...tId=2062264&cp
b)Auto Kit for iPod w/ Dock Connector.
http://catalog.belkin.com/IWCatProdu...duct_Id=149006
c)Minijack Ground Loop Noise Isolator. (MUST for the sound qulity)
http://www.crutchfield.com/S-pqKDOXx...+loop+isolator
d)Regular (or gold platted) male to male cable.
http://www.crutchfield.com/S-pqKDOXx...14&I=043182970
Installation:
1)install 90° charger adaptor into your ordanary outlet.
2)install item b) into one of the outlet of your new adaptor.
3)install item c) into your AUX output.
4)install item d) between your item b) and item c).
5)Enjoy your new car audio!!
Pictures
Edit: Altered first two URLs. thanks.
Old 02-20-06, 09:37 AM
4TehNguyen
4TehNguyen's Avatar
belkin link doesnt seem to work, does the center console close?
Old 02-20-06, 09:43 AM
tonyxcom
tonyxcom's Avatar
where is the "integration"
Old 02-20-06, 10:13 AM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
Hmmm. This...
vs.
Old 02-20-06, 10:17 AM
4TehNguyen
4TehNguyen's Avatar
i would much rather have the ipod near the center console so i can control it and look for a specific song if i wanted
Old 02-20-06, 10:21 AM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
If you have real integration you never need to touch your iPod! You can see everything on the nav screen.
Old 02-20-06, 10:24 AM
4TehNguyen
4TehNguyen's Avatar
i dont plan on getting nav If I were to get a non Nav IS it doesnt have a LCD in place of it correct?
Old 02-20-06, 10:28 AM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
Then info would/show up in the RDS/TEXT area on the LCD base radio.
Old 02-20-06, 12:11 PM
Stillgoing
Stillgoing's Avatar
So to clarify:
1- Once complete, the ipod info is displayed and can be controlled from the NAV? Can it be changed when the car is in motion?
2- Since nothing "invasive" was done, no warranty void issues?
Thanks.
Old 02-20-06, 12:44 PM
aznevoviii
aznevoviii's Avatar
to Sillgoing's answers,
1- No, you would not have a control on your navi screen, you only can change the track over the ipod itself.
2- It would not void warranty.
Also, Yes, the center console still closes and opens correctly.
thanks.
Old 02-20-06, 01:41 PM
mcfly
mcfly's Avatar
Is the 90* adapter really required? I don't see why you just can't plug the Belkin directly into the 12V outlet.
Old 02-20-06, 03:25 PM
JoelPirela
JoelPirela's Avatar
The radioshack 90 degree is required. The cover won't close with just the belkin...
A question. Do you have to unpluf the beling from the outlet once you stop for the day? or it will drain your battery?
Also, do you have to turn off the ipod or the Just pause trick still works once the car is not running???
That's the same set up I have and it works great. I still need the Noise/ground loop reducer but is not that bad once the music is playing.
regards,
Joel
Old 02-20-06, 03:50 PM
aznevoviii
aznevoviii's Avatar
No, you do not have to unplug your belkin everytime you get out. it would not drain your battery.
YES, the pause trick still works when the car shuts off.
thanks
Old 02-20-06, 05:22 PM
kensteele
kensteele's Avatar
I'm not very happy with this setup (not true integration) and will be upgrading the minute a solution is available.
Old 02-20-06, 05:43 PM
mcfly
mcfly's Avatar
Unless you're willing to upgrade your car simply for iPod integration, what exactly are you expecting? Short of a complete new head unit, there's really not much that's going to provide a truly integrated solution.
Quick Reply: Installation: 2nd gen IS Ipod Integration.
