VIP Puddle LED Wiring Diagram
Old 03-09-13, 06:31 PM
RegRover
RegRover's Avatar
Took this a few hours ago, pretty bad and grainy..... But you can see I changed the mirror puddle to white and see a bit of the interior.
Old 03-09-13, 07:34 PM
1sWt2GS
1sWt2GS's Avatar
that looks really good
now time for some wheels!
Old 03-10-13, 02:59 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Originally Posted by HighImStan
Where did you get yours installed at Mariano?
Custom Car Alarms installed mine
Originally Posted by 1sWt2GS
post up the pictures when your done! I want to see how it looks.
Here's mine and my switches on the dash.
Attached Thumbnails VIP Puddle LED Wiring Diagram-d-mance-11.jpg   VIP Puddle LED Wiring Diagram-stereo-bass-knob.jpg
Old 03-10-13, 11:05 PM
rickyrecar
rickyrecar's Avatar
Where did you guys order them from?
Old 06-24-13, 11:20 AM
macjac69
macjac69's Avatar
Hello,
I need some help. I'm wiring in a set of Varad suspension LED's the wiring harness has a +12v lead that can be wired to courtesy lights, alarm output etc. my problem is that when tapped into the + side of the courtesy lights on my IS they don't do anything. When tapped to the - side they do exactly the opposite of the courtesy lights. I'm no elec. engineer but its obvious I'm going to have to mod but I don't know where to begin???
Old 06-30-13, 06:20 PM
aspeckt
aspeckt's Avatar
do you guys have the version 1 or version 2 lights?
Old 07-03-13, 03:37 PM
macjac69
macjac69's Avatar
Don't know how to tell what version it is?
Old 07-03-13, 07:43 PM
jimjaix
jimjaix's Avatar
Version 1 is Chrome that might leave halo around the led
Version 2 is black which eliminates halo spots
Old 07-04-13, 08:34 AM
aspeckt
aspeckt's Avatar
they sent me the version 1 lights that leave a halo, and told me they discontinued the v2 b/c the factory stopped making them? ok? anyway i just spraypainted them gloss black with primer. then i added that new "NeverWet" stuff just so rain water doesnt shorten the life of them.
Old 07-05-13, 07:01 AM
jimjaix
jimjaix's Avatar
spray paint will do the trick.
I read this post from my.is
"i found it alot neater and easier wiring it through another hole. ummm its the big *** plastic clip the holds the loom under the scuff plate. take it out and there should be a rectangular hole, u can get the wire front this hole down through to under the car where there is a plastic grommet in place. after that just put the clip bak in place, hook the carpet bak on and then put the loom in place and click it in. there u go, easier to hide the wiring."
can anyone confirm that this will work on a permium package? it seems like getting power from the rear dome light is a lot of work if we can use the door sill power it would be a lot easier.
Old 09-19-13, 06:54 PM
macjac69
macjac69's Avatar
Default Update
Ok I finally got those suspension lights wired in. I used a reg. auto relay to reverse the -12v output and I wired into the white wire in the box above the driver side kick panel fuse box It's the 8 or10 wire connector on the right side of the box as your looking toward the front of the car.
Lights work in conjunction with the center bulb dome light in the overhead.
Pics to come!
Old 03-21-14, 09:48 PM
Brolic
Brolic's Avatar
So my passenger side puddle light is brighter than my driver. Any clue on what's wrong there guys? Can someone help me.
Dvo
14
03-20-12 11:24 AM
pandy_88
CL of Southern California
10-03-09 11:38 AM
2jzism
11-25-08 02:49 PM
i3leusky
09-19-08 09:05 PM
Quick Reply: VIP Puddle LED Wiring Diagram
