can I use 18x8.5 rims all around on my 350?
Old 02-25-12, 07:26 PM
robertrios
robertrios's Avatar
just cause you drive a lexus dosent mean you want to waste money on tires or pass up a great deal for some added performance gain you will never see in a daily driver situation which is what the OP is asking. Yes they fit, no they wont mess anything up. Tires will be fine for now- later I recommend 235/40/18 but please DO a search and see if other guys went thinner or thicker, im all for a 245 around for a nice ride but you might get a little rub.
PM me your email and ill send a pic over.
Old 02-25-12, 07:45 PM
Sango
Sango's Avatar
As long as it's the right stuff, it's not a waste.
I'm still not sure about the OEM 50mm offset on using 8.5" with the being used the front would be some concern. Jeff Lange or other members may know.
If I looked at Work's Japan's recommendation, it's 8.5 front with offset of 42mm.
Old 02-26-12, 01:11 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
18x8.5 +50mm should fit the front pretty much like stock. Most of the extra width will go inwards (11mm), but that is a pretty small amount.
Jeff
Old 03-08-15, 11:38 PM
japjunkie
japjunkie's Avatar
Just wanted to update this thread as my 2 oem front wheels were bent and one was cracked and curb rashed to hell. I finally came across a pair of mint condition matching 18" split 5 spoke wheels for $60! Catch was they were for the back. The extra half inch made it come pretty close to the A-arm so we added an 1/8" space and bam I was good to go. My wheels must have been really bent, because the ride is much smoother.
ANICK25
12-25-11 08:16 PM
DrZaius7
12-01-11 10:24 AM
dnhemm
03-18-11 02:36 PM
jracerlmn
11-20-09 12:15 AM
Bobby206
11-09-09 10:05 AM
Quick Reply: can I use 18x8.5 rims all around on my 350?
