Water Pump Replacement.
Old 07-11-13, 04:24 PM
Nikon
Nikon's Avatar
is water pump changed under the 70k mile powertrain?
Old 07-11-13, 05:48 PM
4TehNguyen
4TehNguyen's Avatar
yes, many members here have gotten it replaced under powertrain warranty
54k miles here and nothing yet
Old 07-11-13, 06:09 PM
Gville350
Gville350's Avatar
https://www.clublexus.com/forums/is-...-warranty.html
Old 07-11-13, 10:35 PM
MIA_LEX
MIA_LEX's Avatar
my water pump went at 89k on my 07
Old 07-12-13, 09:19 AM
Nikon
Nikon's Avatar
this is good info for everyone. especially considering the high water pump failure rate.
Old 07-30-13, 05:51 PM
MiiK350
MiiK350's Avatar
What sound are you guys hearing to indicate a failing water pump?
Old 07-30-13, 06:06 PM
Gville350
Gville350's Avatar
^Usually a whining pulley noise or pink crust underneath the pump itself.
Old 08-26-13, 10:49 AM
BlkSheep83
6th Gear
BlkSheep83's Avatar
I am picking up my car today after being checked out for a cam gear noise when starting up. It has been going on for about 10K miles but it was happening randomly so it was difficult to diagnose. Anyway, they also found I have the "rough idle" issue and will be replacing my pistons. (Sounds like a sweet deal but hope that's actually true in terms of the engine block being opened and susceptible to new problems) So when they get the pistons in, in about 6-8MONTHS (RIDICULOUS), they are recommending the water pump replacement since they can do it without charging me for the labor if done at the same time as the pistons. I have 73K miles and no known issues with the pump. The consultant told me it's standard to replace at 90K. Does that sound right to everyone? If this is a failing part like I'm reading, I guess it wouldn't hurt to replace it early?
And side question about my cam gear issue... this issue appeared before my warranty expired but wasn't properly diagnosed until after. Any recommendations on course of action I should take with Lexus to get this done for free? As of right now, they want to charge me for the parts but not the labor because it'll be performed when the pistons are replaced too.
Old 08-26-13, 11:00 AM
KillaIS250
KillaIS250's Avatar
It's not "standard" to replace it at 90k. But it seems like for the IS250 a good number of people are seeing water pump failure between 60-80k or so. If they are going to replace it without charging you for labor, I would just get it done. When they did my water pump replacement, I had them replace my serpentine bet as well - it's a fairly cheap part and it comes off when doing the work anyways.
Also with the cam gear issue, did you take it to the dealer for the problem before your warranty expired? If its an issue you brought up before your warranty expired, but couldn't get it repaired at that time you would have a better chance at getting them to cover it.
Old 08-26-13, 12:21 PM
Gville350
Gville350's Avatar
^^I would go ahead and have them put on the new one, just so long as they charge you minimal labor. Same with the new belt.
Old 08-26-13, 09:00 PM
Toxicxk23
Toxicxk23's Avatar
Is there a DIY available?
Old 08-29-13, 04:47 PM
specie
specie's Avatar
I'm going to get this done for peace of mind. Do I order just the water pump, water pump gasket, and coolant?
Old 09-29-13, 06:42 AM
docroger
docroger's Avatar
Default Water Pump service Bulletin
I was told the same thing at the Dealer when I went for a service with the Water pump replacement cost of $879.
I did notice a slight pink color near the pump but not other problems.- i.e. no fluid on the floor or overheating or any noises.
The dealer Advisor at Lexus told me that if there is Any coolant around the water pump it has to be leaking. I wanted to show him the service bulletin below but he did not want to listen.
Look at the Lexus service Bulletin that may help clarify the problem.
waterpump.pdf
or the URL below.
https://www.clublexus.com/forums/att...-waterpump.pdf
Old 11-25-13, 04:06 PM
pwr2loud4u
pwr2loud4u's Avatar
Default Unreliable pumps!
I have an 07 2is and my water pump has a slight leak in it. now it's to the point of having the "rotten egg" smell coming into the cabin. Are there any threads that have a pictorial DIY replacement?
Old 11-25-13, 08:54 PM
Letxen3
Letxen3's Avatar
i got my waterpump replaced under 70k powertrain warranty for having seepage. car had 58k at the time.
Quick Reply: Water Pump Replacement.
